Mixer Control Surface for Mixing in DP
wonder
Post by wonder »
I don't mix much...but I'm doing a mix on a project right now and am looking for a USB control surface to easily ride faders/pots for volume automation.
I use a Tascam DM24 right now and don't have any automation writing capabilities.
1. Anyone have any recommendations on USB control surfaces?
2. are their any that integrate with DP automatically like the 003 does with PT? (tracks automatically sync up to faders) or do I have to assign each track to a fader?
any suggestions are appreciated.
Dual Quad-Core 2.8 GHz Mac Pro 3,1 • Yosemite • 24 GB RAM • MOTU 2408mk3 (x's 2) • DP 10.xx • Finale 25 • Logic • PT 12 • +outboard gear
menright
Re: Mixer Control Surface for Mixing in DP
Post by menright »
There are some really interesting control surface apps for the iPad, if you have one. Cheap, too.
MacBook Pro 17' 2.66 GHz Intel Core i7, 8 GB, DP9.1, MachFive3, Ethno2, Synthmaster, Waves, UVI, Ableton Live
wonder
Post by wonder »
menright wrote:There are some really interesting control surface apps for the iPad, if you have one. Cheap, too.
appreciated.
but i do like having my hands on physical knobs (thats what she said?) as it seems to write the automation more responsively.
elcappn
Post by elcappn »
There are the Artist series controllers from Avid. You could also look into a Mackie Control or Behringer BCF2000. If you only need a single fader there is the Presonus FaderPort. All of these are pretty easy to setup with DP.
Chris
2013 Mac Pro 3.5 6-Core 64GB of RAM, 27" Dell Display x 3, macOS 10.15.7, MOTU 1248, MTP AV, Yamaha S90-es, Dave Smith Prophet 12, OB-6 & Arturia Matrix Brute, DP 10.11, Dorico Pro 2, VEP7, All Oxford plugs, PSP, Pro-Q 3, Kontakt, SoundToys, Softube, Exponential Audio Phoenix Verb, R2, Nimbus & R4, LASS+LS, WIVI Brass+Winds, VSL Harps, Falcon, CineSamples, Spitfire, Output, Heavyocity, Scuffham.
musicman691
Post by musicman691 »
elcappn wrote:There are the Artist series controllers from Avid. You could also look into a Mackie Control or Behringer BCF2000. If you only need a single fader there is the Presonus FaderPort. All of these are pretty easy to setup with DP.
The Presonus FaderPort is not supported in DP8. And depending on the Eucon version (s/w that drives the Artist units) there are issues with that as well. For instance banking channels from the daw gui doesn't bank channels on the controller.
wonder
Post by wonder »
I'm gonna try the korg nanoKontrol2
Hopefully it'll do the job.
Don't know if this is too late, but don't overlook BarfRinger, wonder.
Some good options there.
musicman691
Heard some good things (surprisingly) about the Behringer X-Touch - maybe they've turned the corner on their QA issues?
Klaus
Post by Klaus »
musicman691 wrote:Heard some good things (surprisingly) about the Behringer X-Touch - maybe they've turned the corner on their QA issues?
Are these released somewhere ?
Klaus
musicman691
Klaus
Not to the general public from what I can find although they've been making the rounds of the trade shows and Sweetwater is taking pre-orders for them.
wonder
Post by wonder »
I'm looking into getting rid of my Tascam DM24. Its over 10 years old and since now I"m almost exclusively using CUEMIX ... the Tascam is basically just a speaker controller and 2 channel playback monitor.
I'm going ADAT from my 2408mk2 into the Tascam for playback/recording.
I used to use the Tascam for headphone mixes ... but CUEMIX has taken that over.
Any suggestions on how to replace the Tascams responsibilities but with a surface that can actually control DPs faders? The DM24 can't do that and its a HUGE and almost dead fadered piece of hardware taking up a lot of space.
Are there any control surfaces that can take ADAT in so I can feed DP's output into the surface and then to my control room monitors?
musicman691
wonder wrote:I'm looking into getting rid of my Tascam DM24. Its over 10 years old and since now I"m almost exclusively using CUEMIX ... the Tascam is basically just a speaker controller and 2 channel playback monitor.
If you can switch over to using the spdif on the 2408 there's the SSL Nucleus with 16 faders. See this page: http://www2.solidstatelogic.com/studio/ ... #&panel1-1
Not cheap at $5500 from Sweetwater
SixStringGeek
Post by SixStringGeek »
FWIW, I've just listed my Mackie MCU + 3 Extenders. 32+1(master) faders.
They are up on ebay right now. Seek and ye shall find em.
Hopefully I didn't just breach a 'no gear ads' policy. If I did - :sorry:
wonder
Post by wonder »
In the last few years, Behringer, IMO, has gone from Ford Pinto to Honda Civic. Once used to be a snicker when you mention Behringer but now, i'm seeing some really cool gear and great reviews.
I was looking at the new PowerPlay Headphone setup they have. Looks cool.
kdm
Post by kdm »
I too would like to have some motorized faders/integrated control for DP since there is no Eucon support for DP on Windows (have an Artist Control that is pretty much useless). I had a quick look at the Behringer X32 today and faders, knobs and buttons seems pretty decent - better than Presonus new digital console. Never been a Behringer fan or customer, but the X Touch could be worth considering.
