VEP 5 MAS version and DP Transport
Hi All! Hoping to get some clarification on a feature of vienna ensemble pro 5 MAS version. For some reason I can't get the transport control to work when vienna is the active window. My other DAWs have no issue but DP8 won't do it. I found some very old posts about this being an issue in the past….has anyone had luck resolving it?
thanks!
thanks!
Re: VEP 5 MAS version and DP Transport
?? Sorry but I've never had this problem between DP transport and VEP
DP 10.11 || iMac 2019 5K ||i9 8core 3.6GHz|| 64 GB RAM|| macOS 11.5.1
RME AiOPro || Softube Console 1 ||
The only thing I can get to work is clicking play in VE Pro 5. The space-bar doesn't work within VE Pro. Hardly convenient. Anyone able to use the space-bar within VE Pro running outside of DP?
2012 Mac Pro 12 Core, OS 10.8.5, 64 gigs ram; 2408 (3), 308, DP 8.07 http://www.daveconnor.net
There's a new version out today. You could try that one.
Worth a try - thanks.
Check the post I made earlier today here:Dave Connor wrote:Worth a try - thanks.
http://www.motunation.com/forum/viewtop ... 83#p503683
It lists the fixes and the spacebar transport issue is listed as one of them.
Thanks James, That brings up a good point. I am still running VE as an AU (apologies that I didn't properly associate MAS in the thread title with that version of VE.) I got scared off the MAS version when I saw that VSL had pulled it but perhaps that's ancient news or this new version is the re-release - don't know.
In any case, I asked repeatedly at v.i. control if the MAS advantage is only gained by running it 'inside' DP and never got a straight answer. So I guess my two questions are: is it stable and working well now and is running it within DP the only way to take advantage of it? TIA
