I'm very glad for you! This make me feel bettertoodamnhip wrote:Finished my install … My speed more than doubled running Geek Bench
Of course! Thanks HCJames Steele wrote:Thank HC Markus. He's the one who shared this with the forum to start with.
Geez, my post took so long to complete (internet connection kept dropping out!) I missed your sneaky lil' ol' entry, Sir Markus.HCMarkus wrote:It has truly been a pleasure assisting my fellow composers and recordists in putting together very powerful, yet cost-effective systems.![]()
Danworks, I am wondering, are you are using multiple instantiations of your VIs in your demonstration videos?
I find Apple's Activity Monitor provides are more interesting view of CPU activity than the DP meter, as it shows per-core usage. When running DP on my Hex MP and observing Apple's Activity Monitor, I note that activity is shared across all physical cores fairly equally, with the virtual cores showing a reduced workload.
Because you were previously running a 12 core system, I would expect the increase in clock speed to translate directly to better performance, as any multi-core inefficiencies would be identical regardless of clock speed. The again, expectations based on theory aren't always fulfilled in the real world, are they?
That simply isn't true. DP handles multi cores pretty well actually. From tests I've run DP like almost all DAWs handles a single track on a single CPU though, so you can overload a 12 core machine by placing heavy plug ins all on the same track. If you evenly spread plug ins across dozens of tracks DP handles them 100000000X better than if you stack a few tracks. CPU is far more important for a single track, but multi core is in no way not "really handled" in DP, that's obvious if you have dozens of tracks. The latest iMac has the best single core performance, the i7 in it is great for single core operations, but it's also only a single four core.danworks wrote: On real work environment things are a little different. As I said, as far as I know DAW do not use all the cores as video and graphic apps do. Bidule is a good example of how multi cores isn't really handled and DP is too; therefore even if the the faster feeling is there, is less noticeable.
Unless you don't work on project with 200 audio tracks and 600 plugins, plugs and audio tracks stop to be an issue ages ago. Many times I bring home average pop-rock project with a decent number of plugins on my 2009 MacBookPro with SSD, and I can work with it without any hiccups.Michael Canavan wrote:That simply isn't true. DP handles multi cores pretty well actually.danworks wrote: On real work environment things are a little different. As I said, as far as I know DAW do not use all the cores as video and graphic apps do.
