Triggers?
amerecordingstudio
Triggers?
Post by amerecordingstudio »
Okay, do you guys use triggers on your drums? Right now we're facing a kick drum that my boss would really like to retrigger, he just doesn't like the way it sounds, even with tweaking. So my questino is... is the MOTU trigger plug-in worth dealing with, or should we look at drumagog or somethign like that? So far i've been able to trigger okay with the MOTU one, but ij've used Drumagog in the past and really liked it.
Any suggestions?
Dual G5 2.0Ghz 1.25Gb running DP4.52 in OSX 10.4.2 with M-Audio FW410
Dual G5 1.8Ghz 1.5Gb running DP4.52 in OSX 10.3.9 with MOTU 2408 MkIII
oldguitars
Post by oldguitars »
Drumagog is the way to go, or beat detective on someones PT rig. Trigger is a great idea but it doesn't work right for accurate drum replacement.
3GHz 8 core, 6GB ram, DP 5.13, OSX.4.11, PTLE 7.4.2, Rosetta 200 digi003, waves platinum, mach five, distressors, ADL 1000, API, Calrec, UA mic pres, neumann, AT, shure, Sennheiser and rode mics...old guitars and drums...nord rack 2, s90, micro korg...yaddda yadda.
http://myspace.com/monkeydenrecording
terencepalmer
Post by terencepalmer »
The trigger plug-in in DP doesn't seem to be very accurate. Neither is Soundreplacer in Pro-tools. Drumagog is one way to go, but I can't possibly say enough about Aptrigga. It does everything you want it to do. It's incredibly flexable and it is nearly invisible.
http://apulsoft.ch/aptrigga/index.php
Plus, it's pretty cheap. Under $50.
amerecordingstudio
hmm, looks interesting... and much cheaper, but i'd really like to have a MIDI output like drumagog or trigger.
Fibes
Post by Fibes »
amerecordingstudio wrote:hmm, looks interesting... and much cheaper, but i'd really like to have a MIDI output like drumagog or trigger.
Why?
Have you looked at the entire package for Apptrigga?
Just pay the 40 bucks, shut up and thank us later.
Yes, i was rude.
Fibes
"You can like it, or not like it."
DP 7.24, 12 Core 2.66, Reason, Live, UAD-2 full meal deal, Sonalksis 315 & 517, DUY Everpack, Altiverb 6, Apptrigga, Autotune 5, OHM Force Experience, Audio Damage Dishord/Adverb/Dubstation, PSP full meal deal, Camelphat/Space, Wave Arts Power pack and many more.
yofo
Post by yofo »
I Googled it and there was no mention of where to buy it ? Where to you buy it ?
Mac OSX 10.6.8 2 x 2.66 GHz dual-core Intel Xeon 8GB 667 MHz DDR2 FB-DIMM RME Fireface 800
Spikey Horse
Post by Spikey Horse »
RTFWS! :wink:
You can buy/download from the website (link above). Also can download demo - I did, it works very well on the little test I did so far.
Klaus
Post by Klaus »
I use it live for kick trigger, although in Rax ...
Take care
Klaus
jonotron
Post by jonotron »
avoid clavia Ddrum triggers, the kick drum is hopeless and double triggers all the time. If you are a metal artist this may suit you!! Yamaha do a great module to convert a mic signal into triggers, works perfectly every time. Will get back to you with the model, i'm not a drummer (but i know loads)
midilance
Post by midilance »
Actually, the ddrum triggers are quite good when used with the ddrum modules. Many of the top metal bands have been using ddrum triggers and ddrum modules (ddrum AT / ddrum3 / ddrum4) for a long time. They have been the best choice that works to the drummers' (and drum techs") satisfaction. They are so good that they tend to cause problems when used with cheaper, less competent trigger modules. The lion's share of the problems are due to lackluster modules.
Mac Studio m2 Max // OS 14.7// DP 11.34 // MotU Ultralite mk4 // Komplete Ultimate 15 // Arturia V Collection 9 // Korg Collection // Stylus RMX 1.8 // Omnisphere 2.6.2c // Scarbee Keys and Basses // T-Racks 5 Max // Amplitube 5 Max // BFD3 // Blue3 // PolyM //
TheHopiWay
Post by TheHopiWay »
The three best choices are;
Apptrigga2, Apptrigga2 and Apptrigga2.
If those don't work out go to
http://apulsoft.ch/
They sell a product there called Apptrigga2 that will do what you want.
Resonant Alien
Post by Resonant Alien »
apTrigga2....hands down....it is fast, no latency, cheap and just plain works.
Astia
Post by Astia »
We have been testing Drumagog but it doesn‘t seem to be too accurate. Some hits are off by a random amount of ms on the Advanced Mode. The Simple Mode has proven to be the best choice. Drumagog is ok when the real sound is not used at the same time (snare track, aux send to an aux track with Drumagog inserted).
I have been trying out a method of using a long track with sine wave, beat detecting a snare track, selecting both snare track and sine wave, Copy Beats from snare track to sinve wave track, Create Soundbites From Beats on sine wave track, set all lenghts app 16th notes, open pitch, copy pitch to a MIDI track. Now I have the snare track as MIDI too.
This way the hits are in correct place but usually after cutting it is very important to check that the cuts are in correct places.
Mayby Motu should make a new "audio to MIDI plugin" using this techique including the velocity of a track.
Mayby I should get a patent for it? :D
G5 2x2.75GHz, 4G RAM, OSX 10.4.5, DP4.61, Mach5, 2408mkIII, 1296, ExpressXT, AutoTune3, Waves Renaissance, PowerCore mkII, UAD-1, 2-1176, Distressor, LA2A, TLAudio VTC, Mackie DXB200 w/3xUAD-1..
Rokrok & siihen ralliin!!!
