First Yosemite 10.10.2 Kernel Panic - not like the others!
Re: First Yosemite 10.10.2 Kernel Panic - not like the other
The latest build of Safari is having quite a problem with adware. I have experienced some of it and the support boards are thick with complaints starting 1/30.
Sorry for the delay in responding, cuttime. I had to clone my drives and bring the can to the shop. Thanks for the link! I ran the program (easy sneezy!) and no adware was detected. I thought it would find plenty. I use Little Snitch which doesn't allow internet access to specified apps. I suspect that has helped keep that junk off my machines.cuttime wrote:MLC, I know you are a savvy user, so no admonishment is intended, but even the most sophisticated users can trip up from time to time.MIDI Life Crisis wrote: Personally (and I'm not a wacko conspiracist type) I suspect some kind of ad tracking.
This couldn't hurt and has helped me:
http://www.adwaremedic.com/index.php
There are some new adware problems that such software cannot remove.because they cause problems before they are installed.
You click on a page and you get this pop up that you need to install .... can be a software Updater including Adobe Flash, there are a number of them. Anyway, your browser freezes. You know that if you click on the install or update button, this is bad but your browser freezes... If you force quit the browser, the page will try to load when you come back and it feels like an endless loop.
This has become a real issue because the problem is not with your Mac or PC; its on the page you went to. Those adware remover programs can't help because nothing was loaded (unless you clicked on the button). It will keep happening until the page administratior finally believes all the complaints, finds the hidden code and removes it from the page.
Here's the only thing I've found that works: when you see the window and nothing responds, you can still click on the url bar. Erase the url, type in another web site and Enter. The page will change and the pop-up screen goes away.
Banjohangout.org is one of those sites with a problem right now. The admin was able to fix it so that it can be viewed in FireFox but Chrome and Safari still have problems.
Removing aware extensions manually is easy but no fun. I was fooled about three weeks ago by one pretending to be a Flash updater. It installed into FireFox, Safari and Chrome. I had to log in with Opera to find out how to remove it.
Having learned the lesson, if I get a pop up that Flash player needs updating, I go to Adobe and download the updaters if needed.
