Bounce with Multiple Outputs
Aaron Guidry
Post by Aaron Guidry »
Hello!
I'm trying to bounce two tracks with two different output assignments down to one stereo WAV. Is this possible?
The "Bounce to Disk" pop-up menu only allows me to choose one source; consequently, only one track gets bounced to the stereo WAV. :(
DP 11.31, Mac Studio M2 Ultra, 128GB Memory, Sonoma 14.3.1
Re: Bounce with Multiple Outputs
Change the outputs to the same one. You cannot bounce two outputs to a single file AFAIK. You might bus them but I think you need an "active" output to BTD.
Aaron Guidry
My only issue with changing the outputs to the same one is that I'm running one output 15-dB less than the other. So, the balance between the two tracks will be off.
Can you bus them to an AUX and adjust it there? Then send the AUX to a single out.
Aaron Guidry
OR...
how do I set up Master Faders to control different outputs globally?
that might not make sense in this situation, but I think it might help me.
You'll still need setup an aux track, I think. Have you tried that yet?
Aaron Guidry
I'm not quite sure what to do once the aux track is set up.
Bus the tracks to the aux and set the output to a single output.
