Trim Bite Volume bug
csavetman
Post by csavetman »
Hi all-
Wondering if anyone else has encountered the following quirk.
When adjusting the bite volume layer in the sequence editor using the trim tool, the change doesn't take effect immediately or even on playback. Selecting undo, and then redo from the edit menu, finally let's you hear what you've modified.
Anyone else experience this?
thanks
Carlos
Using DP 8.07 / Mac Dual quad core xeon / OS 10.8.5
csavetman
Re: Trim Bite Volume bug
Post by csavetman »
To be more specific…
Have track set to display bite volume layer
Select a region of audio in sequence editor.
Access the trim/ scale tool by pressing the / key
Hold key-Drag up, or down on selection. Volume change displayed and breakpoints added.
Play back- no audible change.
Hit undo from edit menu, then redo .
Play back - all good.
Carlos
Yes, I'm seeing the same thing.
