UDPATE: Went to MOTU and downloaded and installed the MOTU Audio Installer 64254 from 10/17/14. I had 64208 from 10/15/14. Jeepers... that was odd. I don't think I've had that happen to me before.
I suspect you are right. The 5770 has some latent issues:James Steele wrote:FWIW, I don't think this has anything to do with the new processor. It appears related to having a third display connected to my ATI 5770 and I'm suspecting it MAY only happen when mirroring one display onto another.
I don't know what this stuff means, and I see a lot of issues with USB. I actually misread "iokit" as "ilok" is guess and it reminded me that I just upgraded to the latest iLok driver prior to the issue, plus moved my iLok key to the built in USB hub of my 30" cinema display... WHICH is connected to a mDP port on the 5770 with an active Apple mDP-to-DVI adapter, which is drawing power via USB and I had connected the USB connector for the 30" monitor's built in hub to the USB pass thru on that adapter. I also had they keyboard attacked to the 30" monitor hub too for a while.Anonymous UUID: 2DA290E6-1A1E-04D4-3751-676CF37112F0
Wed Jan 7 13:21:32 2015
*** Panic Report ***
panic(cpu 0 caller 0xffffff800b179458): "a freed zone element has been modified in zone kalloc.128: expected 0xdeadbeefdeadbeef but found 0xdeadbeeedeadbeef, bits changed 0x100000000, at offset 24 of 128 in element 0xffffff8039c33900, cookies 0x3f00115868903c86 0x5352118c45e1551"@/SourceCache/xnu/xnu-2782.1.97/osfmk/kern/zalloc.c:496
Backtrace (CPU 0), Frame : Return Address
0xffffff82d241aca0 : 0xffffff800b13a811
0xffffff82d241ad20 : 0xffffff800b179458
0xffffff82d241ae50 : 0xffffff800b142ef1
0xffffff82d241ae80 : 0xffffff800b65e513
0xffffff82d241aec0 : 0xffffff800b6ed261
0xffffff82d241aee0 : 0xffffff7f8bdacf60
0xffffff82d241af30 : 0xffffff7f8bdad231
0xffffff82d241af70 : 0xffffff7f8bdaa000
0xffffff82d241ba90 : 0xffffff7f8b9f066e
0xffffff82d241bad0 : 0xffffff7f8b9ef1a4
0xffffff82d241bb00 : 0xffffff7f8bda7b43
0xffffff82d241bb30 : 0xffffff7f8b9ee689
0xffffff82d241bb60 : 0xffffff7f8bda7fd7
0xffffff82d241bb80 : 0xffffff800b6b57ed
0xffffff82d241bbc0 : 0xffffff800b6b530f
0xffffff82d241bc40 : 0xffffff800b6b01f3
0xffffff82d241bc80 : 0xffffff800b6afe51
0xffffff82d241bcc0 : 0xffffff800b6afcd3
0xffffff82d241bd00 : 0xffffff7f8bac6029
0xffffff82d241bd30 : 0xffffff7f8bac6a43
0xffffff82d241bdd0 : 0xffffff7f8c317208
0xffffff82d241be00 : 0xffffff7f8c316868
0xffffff82d241be40 : 0xffffff7f8c3164e9
0xffffff82d241be70 : 0xffffff800b6b57ed
0xffffff82d241beb0 : 0xffffff800b6b530f
0xffffff82d241bf30 : 0xffffff800b6b01f3
0xffffff82d241bf70 : 0xffffff800b6b5f83
0xffffff82d241bfb0 : 0xffffff800b2192c7
Kernel Extensions in backtrace:
com.apple.iokit.IOUSBFamily(705.4.14)[E15E9DC8-410F-3612-8371-E5FECD939E0D]@0xffffff7f8baae000->0xffffff7f8bb12fff
dependency: com.apple.iokit.IOPCIFamily(2.9)[766FC23F-452C-3B74-951C-598BB17BCF06]@0xffffff7f8b924000
com.apple.driver.AppleUSBComposite(705.4.9)[8E052C83-2E50-3632-AC11-0524DFAF2449]@0xffffff7f8c315000->0xffffff7f8c31efff
dependency: com.apple.iokit.IOUSBFamily(705.4.14)[E15E9DC8-410F-3612-8371-E5FECD939E0D]@0xffffff7f8baae000
com.apple.iokit.IOAudioFamily(200.6)[2ED56C8A-6B84-3B50-9B0A-67EEB8EF3FE3]@0xffffff7f8b9eb000->0xffffff7f8ba19fff
dependency: com.apple.vecLib.kext(1.2.0)[BBD5DF5B-D295-3151-ABBE-1EDF8A5EF556]@0xffffff7f8b974000
com.line6.driver.xtaudio(7.3.7)[438BAC2D-0AA5-37B6-BA34-75B77F293070]@0xffffff7f8bda4000->0xffffff7f8be61fff
dependency: com.apple.iokit.IOAudioFamily(200.6)[2ED56C8A-6B84-3B50-9B0A-67EEB8EF3FE3]@0xffffff7f8b9eb000
BSD process name corresponding to current thread: kernel_task
Mac OS version:
14B25
Kernel version:
Darwin Kernel Version 14.0.0: Fri Sep 19 00:26:44 PDT 2014; root:xnu-2782.1.97~2/RELEASE_X86_64
Kernel UUID: 89E10306-BC78-3A3B-955C-7C4922577E61
Kernel slide: 0x000000000ae00000
Kernel text base: 0xffffff800b000000
__HIB text base: 0xffffff800af00000
System model name: MacPro5,1 (Mac-F221BEC8)
There are too many things that worry me now. Could it be the graphics card? I can swap it out with my office Mac and test it. If it's NOT that... then could this be related to the hexcore upgrade I installed and new firmware? I could also try a totally clean software install.Anonymous UUID: 2DA290E6-1A1E-04D4-3751-676CF37112F0
Wed Jan 7 14:28:43 2015
panic(cpu 4 caller 0xffffff8010179458): "a freed zone element has been modified in zone kalloc.128: expected 0xdeadbeefdeadbeef but found 0xdeadbeeedeadbeef, bits changed 0x100000000, at offset 24 of 128 in element 0xffffff80588b8380, cookies 0x3f001121325637ce 0x535218a61041dc3"@/SourceCache/xnu/xnu-2782.1.97/osfmk/kern/zalloc.c:496
Backtrace (CPU 4), Frame : Return Address
0xffffff82ccdfb710 : 0xffffff801013a811
0xffffff82ccdfb790 : 0xffffff8010179458
0xffffff82ccdfb8c0 : 0xffffff8010142ef1
0xffffff82ccdfb8f0 : 0xffffff8010662c78
0xffffff82ccdfb920 : 0xffffff8010662e76
0xffffff82ccdfb960 : 0xffffff80106631a3
0xffffff82ccdfb990 : 0xffffff80106b4c6c
0xffffff82ccdfba10 : 0xffffff80106b01f3
0xffffff82ccdfba50 : 0xffffff80106afe51
0xffffff82ccdfba90 : 0xffffff80106afcd3
0xffffff82ccdfbad0 : 0xffffff7f90db5d18
0xffffff82ccdfbb00 : 0xffffff7f90da7bb2
0xfffff
Model: MacPro5,1, BootROM MP51.007F.B03, 6 processors, 6-Core Intel Xeon, 3.33 GHz, 24 GB, SMC 1.39f5
Graphics: ATI Radeon HD 5770, ATI Radeon HD 5770, PCIe, 1024 MB
Memory Module: DIMM 1, 8 GB, DDR3 ECC, 1333 MHz, 0x80AD, 0x484D54333147523741465234432D48392020
Memory Module: DIMM 2, 8 GB, DDR3 ECC, 1333 MHz, 0x80AD, 0x484D54333147523742465234432D48392020
Memory Module: DIMM 3, 8 GB, DDR3 ECC, 1333 MHz, 0x80AD, 0x484D54333147523742465234432D48392020
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x87), Atheros 5416: 4.0.74.0-P2P
Bluetooth: Version 4.3.1f2 15015, 3 services, 19 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en2
PCI Card: ATI Radeon HD 5770, Display Controller, Slot-1
PCI Card: Universal Audio UAD-2 Duo, Other Multimedia, Slot-4
PCI Card: pci137a,5, Audio, Slot-3@4,0,0
Serial ATA Device: Samsung SSD 840 EVO 250GB, 250.06 GB
Serial ATA Device: HL-DT-ST DVD-RW GH41N
Serial ATA Device: WDC WD6401AALS-00L3B2, 640.14 GB
Serial ATA Device: ST500DM002-1BD142, 500.11 GB
Serial ATA Device: SAMSUNG HD103SJ, 1 TB
Serial ATA Device: WDC WD6400AAKS-41H2B0, 640.14 GB
USB Device: USB2.0 MFP(Hi-Speed)
USB Device: Hub
USB Device: Hub
USB Device: Apple Cinema HD Display
USB Device: Hub
USB Device: PODxt
USB Device: Keyboard Hub
USB Device: USB Receiver
USB Device: Apple Keyboard
USB Device: Hub
USB Device: iLok
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
USB Device: AlphaTrack
FireWire Device: built-in_hub, Up to 800 Mb/sec
FireWire Device: Liquid Mix, Focusrite Audio Engineering Ltd (design by Sintefex Audio Lda), Up to 400 Mb/sec
Thunderbolt Bus:
I guess I could do Mavericks. Final Cut Pro X requires that as the minimum. I'm wondering if it's more stable than Yosemite. At least I won't have to worry about zapping NVRAM and forgetting to turn Trim off. Decisions, decisions.MIDI Life Crisis wrote:ML or Mavericks?
Yeah... I'm already mostly done with a long 5GB download of the Yosemite Installer. I'll probably just do the same thing and hope we see a 10.10.2 before long.MIDI Life Crisis wrote:I found Mavericks to be quite stable on my 8 core. Yosemite is a PITA on many levels but I really don't want to drop back on the new machine. I have to reinstall everything from scratch in a couple of weeks and have confidence things will shake out in a few months. I don't want to migrate again at that point- just move on and get work done. A couple of Yosemite and DP updates and maybe a few other apps and I think things will be fairly stable after that, but you know know...
