AudioDesk 4 now available - free for MOTU interface owners
Was on MOTU.com this morning and noticed this.
AudioDesk 4 FREE DOWNLOAD for all MOTU audio interface owners
http://www.motu.com/download
Finally, a Windows version, too.
If it's like the Mac version, it will not work without a MOTU interface. This might be useful for troubleshooting, too.
BTW, if you have DP 8 for Windows, you do not need this download. AudioDesk is an audio only (no MIDI) 'lite' version of Digital Performer for owners of MOTU hardware.
Re: AudioDesk 4 now available - free for MOTU interface owne
It's been there for a few weeks.
What do you mean about not needing this download if you have the DP 8 for Windows? How are things different from the Mac versions?
He's posting this in the DP [Windows] forum, so the assumption is that DP Windows users are reading this and they don't need AudioDesk if they already have DP. Might be good to post this in the MOTU Hardware forums also I guess.bayswater wrote:It's been there for a few weeks.
OK, I see. The same advice applies to Mac users. I thought there was some Mac / Windows difference I hadn't noticed.
I thought that's where I posted it–oops. Yes, it should be moved there.Might be good to post this in the MOTU Hardware forums also I guess.
Mac users have had AudioDesk since v.1 – how many of us first came to DP via the upgrade path besides me? Old news, I figure.OK, I see. The same advice applies to Mac users.
Although MOTU hardware has been available to Windows users for many years now, AD-4 is the first bundled DAW for those owners.
I should look at the feature set again. I wonder what efficiencies might be gained for remote work with borderline/challenged computers.
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.34
Has anyone got this to install on Windows yet?
I've had several tries so far and always get fatal error 0x80070643 after less than 5% of the install process.
Have you seen this error. Did you figure out how to fix it?
Thx
Thx
Try this:RonaldDumsfeld wrote:Has anyone got this to install on Windows yet?
Thx
Cause
This issue occurs on servers that have the Windows Security Update KB2918614 installed.
A page of workarounds and links can be found here:
http://www.symantec.com/business/suppor ... TECH224584
More pages:
http://support.microsoft.com/kb/920660
https://social.technet.microsoft.com/Fo ... serverwsus
Thanks Mike
I'm on it. Might take a while. Seems like error 0x80070643 is something of a bucket code for a number of different issues. So I'm going to be careful and take my time. Don't want to make things worse given that everything else is currently hunky dory.
I've already run the MS NET framework scan utility on all my versions and I get a clean bill of health on all of them. So that's one potential cause down.
Plenty more to go.....
AudioDesk 4.01 incompatible with Windows Vista 64. Official.
Anyone got it working on 7 or 8.1?
Same issue over here.
Can not install on my Windows 8 used several compatibility ways.
0x80070643 - Fatal error durign installation.
I post the error part of the log file right here.
[0FC4:23A4][2015-02-22T12:40:37]: Applying package: ADData.msi, action: Install, path: C:\ProgramData\Package Cache\{3CEB86EC-F7BC-4E97-BD2D-B842C842DF93}v4.0.64520.0\ADData.msi, arguments: ' ALLUSERS="1"'
[0FC4:23A4][2015-02-22T12:41:24]: Error 0x80070643: Failed to install MSI package.
[0FC4:23A4][2015-02-22T12:41:24]: Error 0x80070643: Failed to execute MSI package.
[1E48:1E84][2015-02-22T12:41:24]: Error 0x80070643: Failed to configure per-machine MSI package.
[1E48:1E84][2015-02-22T12:41:24]: Error 0x80070643: Failed to execute MSI package.
[0FC4:23A4][2015-02-22T12:41:24]: Removing cached package: {3CEB86EC-F7BC-4E97-BD2D-B842C842DF93}v4.0.64520.0, from path: C:\ProgramData\Package Cache\{3CEB86EC-F7BC-4E97-BD2D-B842C842DF93}v4.0.64520.0\
[0FC4:23A4][2015-02-22T12:41:24]: Removing dependency: {9ab000f2-7fd3-4c2a-84fd-854af04fee13} on package provider: {3C2CC1B4-3AD2-51AB-9215-FEA7FF140875}, package ADx64.msi
REMOVED DEPENDENT!
THERE WERE NO SUB-KEYS!
RELATED SEARCH 0 - {3C2CC1B4-3AD2-51AB-9215-FEA7FF140875}
ATTEMPTING REMOVAL
[0FC4:23A4][2015-02-22T12:41:31]: Applying package: ADx64.msi, action: Uninstall, path: C:\ProgramData\Package Cache\{06599345-08B0-41AD-A3CF-21CC20128E5D}v4.0.64520.0\ADx64.msi, arguments: ' ALLUSERS="1"'
[0FC4:23A4][2015-02-22T12:41:31]: Error 0x80070645: Failed to uninstall MSI package.
[0FC4:23A4][2015-02-22T12:41:31]: Error 0x80070645: Failed to execute MSI package.
[1E48:1E84][2015-02-22T12:41:31]: Error 0x80070645: Failed to configure per-machine MSI package.
[0FC4:23A4][2015-02-22T12:41:31]: Removing cached package: {06599345-08B0-41AD-A3CF-21CC20128E5D}v4.0.64520.0, from path: C:\ProgramData\Package Cache\{06599345-08B0-41AD-A3CF-21CC20128E5D}v4.0.64520.0\
[0FC4:23A4][2015-02-22T12:41:31]: Removing dependency: {9ab000f2-7fd3-4c2a-84fd-854af04fee13} on package provider: {93B3BD4A-AF3C-572F-8B91-9225053E7859}, package ADx64Plugins.msi
REMOVED DEPENDENT!
RELATED SEARCH 0 - {93B3BD4A-AF3C-572F-8B91-9225053E7859}
ATTEMPTING REMOVAL
[0FC4:23A4][2015-02-22T12:41:31]: Applying package: ADx64Plugins.msi, action: Uninstall, path: C:\ProgramData\Package Cache\{8163EF21-BDD3-4718-A7DA-1AEAD61228CD}v4.0.64520.0\ADx64Plugins.msi, arguments: ' ALLUSERS="1"'
[0FC4:23A4][2015-02-22T12:41:32]: Error 0x80070645: Failed to uninstall MSI package.
[0FC4:23A4][2015-02-22T12:41:32]: Error 0x80070645: Failed to execute MSI package.
[1E48:1E84][2015-02-22T12:41:32]: Error 0x80070645: Failed to configure per-machine MSI package.
[0FC4:23A4][2015-02-22T12:41:32]: Removing cached package: {8163EF21-BDD3-4718-A7DA-1AEAD61228CD}v4.0.64520.0, from path: C:\ProgramData\Package Cache\{8163EF21-BDD3-4718-A7DA-1AEAD61228CD}v4.0.64520.0\
[0FC4:23A4][2015-02-22T12:41:32]: Removing dependency: {9ab000f2-7fd3-4c2a-84fd-854af04fee13} on package provider: {E3C005A3-F76B-52CE-B876-C7CCCE815479}, package ADx86.msi
REMOVED DEPENDENT!
RELATED SEARCH 0 - {E3C005A3-F76B-52CE-B876-C7CCCE815479}
ATTEMPTING REMOVAL
[0FC4:23A4][2015-02-22T12:41:37]: Applying package: ADx86.msi, action: Uninstall, path: C:\ProgramData\Package Cache\{F8A84F72-4D76-4517-AA4D-093107729684}v4.0.64520.0\ADx86.msi, arguments: ' ALLUSERS="1"'
[0FC4:23A4][2015-02-22T12:41:37]: Error 0x80070645: Failed to uninstall MSI package.
[0FC4:23A4][2015-02-22T12:41:37]: Error 0x80070645: Failed to execute MSI package.
[1E48:1E84][2015-02-22T12:41:37]: Error 0x80070645: Failed to configure per-machine MSI package.
[0FC4:23A4][2015-02-22T12:41:37]: Removing cached package: {F8A84F72-4D76-4517-AA4D-093107729684}v4.0.64520.0, from path: C:\ProgramData\Package Cache\{F8A84F72-4D76-4517-AA4D-093107729684}v4.0.64520.0\
[0FC4:23A4][2015-02-22T12:41:37]: Removing dependency: {9ab000f2-7fd3-4c2a-84fd-854af04fee13} on package provider: {4237B8CC-1230-50EE-B4DE-33BAF1127E7A}, package ADx86Plugins.msi
REMOVED DEPENDENT!
RELATED SEARCH 0 - {4237B8CC-1230-50EE-B4DE-33BAF1127E7A}
ATTEMPTING REMOVAL
[0FC4:23A4][2015-02-22T12:41:38]: Applying package: ADx86Plugins.msi, action: Uninstall, path: C:\ProgramData\Package Cache\{8C0A14B9-8093-47CF-B1F8-12156A434D33}v4.0.64520.0\ADx86Plugins.msi, arguments: ' ALLUSERS="1"'
[0FC4:23A4][2015-02-22T12:41:38]: Error 0x80070645: Failed to uninstall MSI package.
[0FC4:23A4][2015-02-22T12:41:38]: Error 0x80070645: Failed to execute MSI package.
[1E48:1E84][2015-02-22T12:41:38]: Error 0x80070645: Failed to configure per-machine MSI package.
[0FC4:23A4][2015-02-22T12:41:38]: Removing cached package: {8C0A14B9-8093-47CF-B1F8-12156A434D33}v4.0.64520.0, from path: C:\ProgramData\Package Cache\{8C0A14B9-8093-47CF-B1F8-12156A434D33}v4.0.64520.0\
[1E48:1E84][2015-02-22T12:41:38]: Error 0x80070643: Failed to execute apply.
[0FC4:23A4][2015-02-22T12:41:38]: Removing bundle dependency provider: {9ab000f2-7fd3-4c2a-84fd-854af04fee13}
[0FC4:23A4][2015-02-22T12:41:38]: Removing cached bundle: {9ab000f2-7fd3-4c2a-84fd-854af04fee13}, from path: C:\ProgramData\Package Cache\{9ab000f2-7fd3-4c2a-84fd-854af04fee13}\
[1E48:1E84][2015-02-22T12:41:38]: Apply complete, result: 0x80070643 restart: No
REMOVED DEPENDENT!
ATTEMPTING REMOVAL
REMOVED DEPENDENT!
ATTEMPTING REMOVAL
REMOVED DEPENDENT!
ATTEMPTING REMOVAL
REMOVED DEPENDENT!
ATTEMPTING REMOVAL
The C:\ProgramData\Package Cache\{3CEB86EC-F7BC-4E97-BD2D-B842C842DF93} folder and package ADData.msi is probably missing in the install.
I recently got a Microbook II, got it going, then enthusiastically installed AD hoping to jump right in and start recording. My AD 4.01.64520 installation "works" on Windows 7 32 bit, but crashes every time I try to point to my Native Instruments plug-ins. I opened up a tech support ticket for this and they could duplicate the issue. So I'm hoping for an update someday. By the way, it works fine in the DP demo I downloaded.
So I was hoping to spend my energy on the learning curve and trying to get up to speed, not trying to get the software to just work. Now, I'm frustrated enough that I am looking at other entry level DAWs that are more Windows friendly. Hrmph.
Audio Desk to DP is priced as an Upgrade. Just saying...mike wrote:I recently got a Microbook II, got it going, then enthusiastically installed AD hoping to jump right in and start recording. My AD 4.01.64520 installation "works" on Windows 7 32 bit, but crashes every time I try to point to my Native Instruments plug-ins. I opened up a tech support ticket for this and they could duplicate the issue. So I'm hoping for an update someday. By the way, it works fine in the DP demo I downloaded.
I don't understand what you mean?mikehalloran wrote:Audio Desk to DP is priced as an Upgrade. Just saying...
