DP 8 crash on statrup (MW leveler )
apanacci
Post by apanacci »
Hey guys, on startup DP8 crashes and it says it is MW leveler. It says to remove which I do and then it starts up fine. Anyone have that problem and if so how do I make it work again, thanks
2012 6 Core 5.1, MacPro , (32 gigs Ram) Monterey, Radeon 570, 2013 MacPro #1 12 Core, (64gigs ram) ,2013 MacPro #2, 8 Core .(64 gig ram), Monterey, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT , DP11 , PT 2024 , Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 12, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
Re: DP 8 crash on statrup (MW leveler )
Does it have a plist or preference file? Maybe a corrupt presets list?
Phil O
Post by Phil O »
Just tried inserting leveler on a track and it works fine, also tried quitting and re-launching and that worked fine too, so I don't think it's a bug. If you go to Preferences>Audio Plug-ins you can select Leveler and ask it to re-examine the file. Worth checking out IMHO.
I've used the leveler in DP8 as well. No problems.
Post by Shooshie »
MIDI Life Crisis wrote:Does it have a plist or preference file? Maybe a corrupt presets list?
+1
I'd pull these things out and make new prefs and lists just to see if that fixes things.
Usually, when I get an error that something won't load or that a MOTU plug is corrupt or missing, reinstalling DP 8 fixes the probem. I've had to do this 5 or 6 times, now.
The only time I had to trash Preferences was when I got the screen freeze before the wave form finished drawing (I now forget which old plug I was trying to make work-- it was so last week--but I renabled something and DP blew up). It's the first time in 17 years that I've ever done that--thanks to the threads where this fixed this issue for others.
Anyway, after trashing preferences and getting DP 8 working, the Trim plugin didn't load. Reinstalling DP 8.07 and repairing Permissions got me working again.
apanacci
Post by apanacci »
Thanks Mike , will try that ! Makes sense.
You know, I get that as well sometimes, but it's intermittent. Something $hit loads and sometimes it don't. I do believe DP is due for an upgrade but not being in the beta loop I can't know when. It is definitely due for one.
Dave?
Dave's not here. It's effen Xmas, dude! Whaddayawant? LOL
Merry Christmas! Hoe ho ho...
