Isn't it possible to clear the Select Similar key commands?
I want to use the key command ctrl-alt-S for a window set. But since there's a binding conflict with the Select Similar (by type) command in the Edit Menu/Search I want to clear that one. However I can't find it in the Commands Window.
Windows 11, DP 11
https://www.youtube.com/channel/UCOI37x ... 8vAQJwNm_A
- Shooshie
Re: Isn't it possible to clear the Select Similar key comman
If it's a regular menu item with a keyboard command listed in the menu, I think you cannot change those. Others should be in the Commands Window.
Shoosh
Shoosh
I think I know how to do it. Just open the edit search settings and delete either that setting or just clear the key command.
Windows 11, DP 11
