RealGuitar 3 by Music Lab fails in DP8
- Primary DAW OS: Windows
DP 8.06, Sonar X3e, Sony Sound Forge, Windows 7, 16 Gigs RAM, Intel Core i7 4.0 GHz, RME Hammerfall, UAD-2Duo, MOTU MIDI Express 128, MUSE Receptor VIP, Deagan Round-top Orchestral Bells, Yamaha S6 Concert Grand, Clavinet D6, UA 2-610
- FMiguelez
Re: RealGuitar 3 by Music Lab fails in DP8
You need to be more specific. What exactly do you mean by "not working"?
Is it a VI setup problem?
Does DP see the VI?
Remember that you need one track for the actual VI, and at least one MIDI track for firing the samples. You can do that, plus add a folder, with everything routed, in one easy step with the Add Instrument With Options command (in the TO with the contextual menu).
Does DP see the VI?
DP says RealGuitar doesn't pass the scan. It shows up as a "failed" plugin.
I have all three of Music Lab's products (including RG3) and all three have passed DP8's plugin tests. However, not without some trial and error, including some emails back and forth with Konstantin at Musiclab.
Bottom line: you have to be SURE that the 32 bit version of the .dll files are not the ones being picked up by DP8 or it will reject the plugin. The best thing to do is to start from scratch by uninstalling RG3 and manually deleting any artifact files and folders, so you have a clean slate. Then do a new install. Then hunt down the 32 bit .dll and kill it. I believe it will be in the c: / program files (x86) / VST plugins folder (not 100 % sure). The 64 bit version will be in its own folder area, like c: \ program files \ musiclab \ etc.etc. It will NOT be in the traditional c:\programfiles\vstplugins folder where many plugins put their dll files. And that is why DP8 is rejecting it, because it cannot find the .dll file. As dar as DP8 is concerned, RG3 doesn't exist on your computer. So ... go into DP8 - preferences - plugins and ADD the c:\program files \ music lab \ vst plugins (?) folder, then close DP and reopen and it should work.
- Kurt Cowling
I've also found that MusicLab products need to be authorized in stand alone mode first, then they pass inspection (my experience is on a Mac, however).
DP 11.34 , 2021 MacBook Pro M1-Max, 2017 iMac Retina 5K 27-inch, Omnisphere, Trilian, Stylus RMX, EZ Drummer 2, Falcon, Real Guitar, Sample Modeling brass. Audio Modeling reeds, strings, Kontakt 6, Flux Pure Limiter 3, PSP Vintage Warmer, PSP MixPack, PSP StereoPack, PSP Impressor, Altiverb 7, Izotope RX10 Standard, Yamaha S-90ES, Yamaha MOXF-8, Yamaha MX60, Sibelius subscription, Adobe CC and Motion 5.
hmmmm....Did thusly, and RG DOES come up, but says "guitars not found." Were the samples in RG2 that I deleted? Don't see them on the disk.
In my opinion, the author's idea is advisable.I will make advertisement freely for your post,recommend it to my frields.Most of my frields are fall in love with rs. And under this circumstance,I also like to play online game,such as RuneScape.I always buy the items online.So I am familiar with the safest and convenient way to buy RS Gold online.There are:Fifa 15 Ultimate Team Coins and Fifa 15 Coins or Runescape Gold
