Buy the lowest model with the video cards that you want and send it to them. If you're really savvy with such work, it's possible to buy them and do it yourself.
If that is a concern, have OWC do the work and purchase their extended warranty on it.
AppleCare is good about covering Apple hardware and, more importantly, gives you three years of call-in support.
If you have a motherboard issue, Apple will not void your warranty because you replaced RAM or a drive etc.
If I did the CPU swap, I would not sell the old processor, however. If there was a hardware problem, I would put Humpty back together before I took it in to be diagnosed--if for no other reason than to see if that fixed it.
If you have been around Macs long enough, you will remember when CPU upgrade kits were widely available. I have a 1.2G kit for a G4 that I need to sell. Same AppleCare concerns then, too.
DP 11.34; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1 2023 Mac Studio M2 8TB, 192GB RAM, OS Sequoia 15.4, USB4 8TB externals, Neumann MT48, M-Audio AIR 192|14, Mackie ProFxv3, Zoom F3 & UAC 232 32bit float recorder & interface; 2012 MBPs (x2) Catalina, Mojave IK-NI-Izotope-PSP-Garritan-Antares, LogicPro X, Finale 27.4, Dorico 5, Notion 6, Overture 5, TwistedWave, DSP-Q 5, SmartScore64 NE Pro, Toast 20 Pro
mikehalloran wrote:If that is a concern, have OWC do the work and purchase their extended warranty on it.
Yes. I remember doing the upgrades
Sounds about right. In any case, I want the Apple Care plan. It comes in handy.
