stereo enhancers
bleached04
stereo enhancers
Post by bleached04 »
does anyone know any good free stereo enhancers if such a thing exists for free...any info would be appreciated...thanks
studiodog
Post by studiodog »
I took some stereo enhancers once. They worked pretty well.
The literature said that if you maintained a stereo image for more than 4 hours to go to your doctor. Fortunately I went back to mono after a couple of hours.
:D
lindymack
Post by lindymack »
studiodog wrote:I took some stereo enhancers once. They worked pretty well.
:D
You are one sick puppy!
:wink:
Lindy
alphajerk
Post by alphajerk »
psp's stereopack... $29 or something like that.... its cheap, not free but worth the $$$
dual gHz, OSX 10.3.9, DP 4.6, PSP plugs [then a load of nice hardware]
sdfalk
Post by sdfalk »
I believe pluggo jr (free)
might include the stereo enhancer and stereo faker plugin but I'm
not sure.
Free though..so it couldn't hurt to try.
http://www.cycling74.com/products/dlpluggo.html
A Metric Halo ULN8-3D…mmmmmmm
Spikey Horse
Post by Spikey Horse »
How you enhance your stereo fields depends very much on what kind of monitors you have to begin with and more importantly what they are resting on - low lying clay or upland chalk etc However, it is standard practice to spread nitrogen pellets, fertiliser and of course good old fashioned 'muck' (cow ••••) on your stereo field to improve the fertility of the top soil. Turning the soil by plough also helps to add air to the mix and laying down proper drainage can help to prevent a muddy low end. Incidently, keeping sheep in the studio is also a good way of making use of an otherwise 'poor grass supply' - although this can make the mix a bit wooley ..... shall I stop? Yes, I think that's enough for now :D
sdfalk
Post by sdfalk »
Spikey Horse wrote:How you enhance your stereo fields depends very much on what kind of monitors you have to begin with and more importantly what they are resting on - low lying clay or upland chalk etc However, it is standard practice to spread nitrogen pellets, fertiliser and of course good old fashioned 'muck' (cow ••••) on your stereo field to improve the fertility of the top soil. Turning the soil by plough also helps to add air to the mix and laying down proper drainage can help to prevent a muddy low end. Incidently, keeping sheep in the studio is also a good way of making use of an otherwise 'poor grass supply' - although this can make the mix a bit wooley ..... shall I stop? Yes, I think that's enough for now :D
That was quite beautiful..
Frodo
Post by Frodo »
I've found Altiverb 5's predelay settings (with 'verb tails off) have helped-- aside from important monitor placement and materials.
Not everyone has A5, but similar tweaking could be done with almost any good reverb's predelay settings or tweaking a very small room setting. Just be careful not to send your signals out of phase.
