Kontakt 5 update, argh, help? [Solved]
BKK-OZ
Post by BKK-OZ »
I stupidly (hindsight) used NI's service center to update to Kontakt 5.3.1.37, and it won't pass DP's AU validation. It isn't even working in stand-alone mode, or as a plugin within Maschine as a host.
I think it might be a database problem - it I try to rescan or update, I get an error message that says 'The database is read-only and cannot be changed'.
I have tried the Repair Permissions routine, I have re-installed from my K9 disks, and I have deleted K5 and run the updater through Service Center again.
Anyone got any ideas?
I am desperately trying to finish a project that uses just little bit of Kontakt, and this is really a pain in the...
Cheers,
BK
- M Kaku
Re: Kontakt 5 update, argh, help?
Ouch! Maybe I'll hold off on updating Kontakt.
BKK-OZ
Post by BKK-OZ »
Hooray for me!
After much tussling with Mr Google and after having gone up a number of blind alleys, I have fixed the problem. As I suspected, there was some sort of problem with the Kontakt database. Maybe it was the install of the update thru the Service Center, maybe it was bad karma - I really don't know.
Here is what I did, in case someone else comes across a similar (dreaded '... database is read only...' error) problem:
1) *Navigate to >Library>Application Support>Native Instruments>Kontakt 5>Db
2) **Delete/move the files therein
3) Restart Kontakt (as a stand-alone application)
--3a-- Kontakt will rebuild its database (sorta)
4) ***In the Kontakt GUI, go to the Database tab, click on the options button
5) Ask Kontakt to Update the database (this might take a few minutes)
6) Close down Kontakt
7) Restart DP, if you asked DP to skip Kontakt during a previous failed scan, you might need to go to File>Preferences>Plugins and ask it to re-scan, otherwise
--7a-- DP will rescan Kontakt on opening
(8) Drink beer
*Note this isn't the library that you normally see. On Mac OS 10.7+ the Library folder is hidden. To access it, click on Finder>Go holding down the Alt key (could be different depending on your keyboard). The real, super-secret Library entry will become visible in the drop-down menu. Select that option, then navigate to the Kontakt database (Db) folder.
**I simply moved out the files to another spot. On the Interwebbies, some say delete, some say delete and empty the trash, but all I did is move the files out of that directory.
***The Options button is near the top of the Kontakt GUI. It is also accessible through the Settings button (little cog wheel near the top right of the interface).
I hope these notes help out others who encounter the same/similar problem in the future.
Cheers,
BK
- M Kaku
Re: Kontakt 5 update, argh, help? [Solved]
Pasted your text in my DP & VI notes. Added it to the "How to prevent Kontakt from ignoring the instrument levels you set."
BKK-OZ
Post by BKK-OZ »
Step 8 is the most important.
Cheers,
BK
- M Kaku
