SampleTank3 PreOrder
Re: SampleTank3 PreOrder
In case you were considering both Mac and PC versions: There are separate Mac and Windows download menus for the Sound files. I verified with support that you can just download the Mac versions of the Sound file folder, and these contain a .exe that can be used to install under Windows. No need to download both versions.
2018 Mini i7 32G macOS 12.6, DP 11.32, Mixbus 10, Logic 10.7, Scarlett 18i8, MB Air, macOS 14.6.1, DP 11.32, Logic 11
Yes that link works. Thanks. I am on my way.bayswater wrote:Mike in the email I got with my serial number, there was a link right in it for the Authorization manager. Clicking on it downloaded version 1.1. That worked fine.
If you already have products installed, you might run into the endless loop where 1.09 kept downloading the 1.09 version as its own update. A little issue on IK's back end.
DP 11.33; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1
2023 Mac Studio M2 8TB, 192GB RAM, OS Sonoma 14.7.1/Sequoia 15.1, USB4 8TB externals, M-Audio AIR 192|14, Mackie ProFxv3, Zoom F3 & UAC 232 32bit float recorder & interface; 2012 MBPs (x2) Catalina, Mojave
- SixStringGeek
I'm into day 3 of trying to get a clean download of the sound file zips. I got 1. 2-8 keep timing out or if they show up, they're not unzippable.
Kind of frustrating.
DP 11.newest on MacBook Air M2 24/2T
Korg Kronos Klassic Keyboard 88, Line 6 Helix
I downloaded the sample files with iGetter no problem. Have you tried a download manager?
Mac Studio M2 Ultra 128G RAM OSX 14.3, 16" MacBook Pro M1 Max, UA Apollo x6, UA Apollo Twin, UAD-2 Satellite (x2)
- SixStringGeek
No, I've just been using safari. I got 2 & 3 now, 4& 5 are coming...dinobass wrote:I downloaded the sample files with iGetter no problem. Have you tried a download manager?
- mhschmieder
I did the installation last night, but the downloading, copying, unzipping, and installing took so long (about four hours total) that I didn't have the energy to try any of the sounds afterwards.
I got one error on SonikSynth during the importation of legacy stuff, but am not sure where the error was as it seemed to import everything (when I compare directories). I'm afraid to delete the original until I know for sure.
Don't forget to hit the circular arrow to rebuild your multis and instruments after importing all your legacy stuff as well as after unzipping the eight parts to the sound set installer.
I'm not fond of the interface; as before, it's a bit fuzzy and hard on the eyes due to the grey/red theme.
iMac 27" 2017 Quad-Core Intel i5 (3.8 GHz, 64 GB), OSX 13.6.6, MOTU DP 11.33, SpectraLayers 11
I haven't installed it yet but the old one you could change the colour,mine was green I think the button was in the top right corner
- mhschmieder
Yes, I think there are probably skins, but the overall rendering is very old-school. Given that the installed files are ten times as big as before, I expected maybe they'd moved forward with sharp anti-aliased fonts. I can't drill into the executable once I show package contents, or into those huge files with the same suffix as the sound banks and which show up in the application support directories, so don't know why ST3 takes almost half a gig on the primary drive.
I had similar problems, and next time will order the boxed version because the massive file downloads are frustrating. But for these, I eventually used iGetter, and while it took time, it did work.SixStringGeek wrote:I'm into day 3 of trying to get a clean download of the sound file zips. I got 1. 2-8 keep timing out or if they show up, they're not unzippable.
I use Folx to download from sites that don't deliver large files reliably. Free at App Store. For this, Safari was fine but only 4 files could be downloaded at a time.
The Opera browser is great for downloading difficult files -- only reason I keep it.
I finally had time to get this up and running I loaded the samples in the same directory as as the old 2.5 stuff but when ST3 scans the directory it doesn't pickup the 2.5 library just the ST3 stuff.
Any ideas?
Any ideas?
A little more poking around and I found the answer.
ST3 comes 25gig of new sounds the rest is the old ST2.5 library.
I'll have to look through it and see if anything is familiar it would be nice if there was a way to tell what was new and what was old.
There's an import function to convert your old libraries. I used it to convert miroalav but st3 appears to have at least most of the same sounds
The import legacy files?
I'm going to try that later and just call it ST2.5
I'll see what happens.
