Since upgrading to 10.9.4, DP asks to set my firewall preferences every single time I launch it. No combination of firewall or software update preferences will prevent this
dialog. I can live with this, but I'm already getting annoyed. Any suggestions?
I haven't been able to get rid of that same irritating window each time I run VE Pro on one of my slaves since at least Lion.
I've also tried every combination in the Firewall settings (VEP is currently included in the "Allowed" category). The other computers, with identical settings, don't show the message. And I have never seen it for DP. Go figure...
--------------------------- "In physics the truth is rarely perfectly clear, and that is certainly universally the case in human affairs. Hence, what is not surrounded by uncertainty cannot be the truth." ― Richard Feynman
Sometimes, this is as simple as running Repair Permissions and rebooting. (you did that already, right? If not, do it now.)
You may have to uninstall and reinstall. If you have a 7.24 CD, run the installer till you get to Easy Install. Click on it and you will see Uninstall. Run it. When done, re-install. You may or may not have to reauthorize. Repair Permissions and reboot. This hurts nothing and will restore any paths that were corrupted during an OS update - I had to do this after 10.9.1.
If you do not have the 7.24 CD, run uninstall from the 7.24 updater, then again from your earlier version CD. Reverse to install (you do not need any of the interim updaters, only 7.24 plus your CD).
DP 11.34; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1 2023 Mac Studio M2 8TB, 192GB RAM, OS Sequoia 15.4, USB4 8TB externals, Neumann MT48, M-Audio AIR 192|14, Mackie ProFxv3, Zoom F3 & UAC 232 32bit float recorder & interface; 2012 MBPs (x2) Catalina, Mojave IK-NI-Izotope-PSP-Garritan-Antares, LogicPro X, Finale 27.4, Dorico 5, Notion 6, Overture 5, TwistedWave, DSP-Q 5, SmartScore64 NE Pro, Toast 20 Pro
