Ridiculously Bad Performance New Project i5 3.5ghz 16gb RAM
- Primary DAW OS: Windows
Hi guys, this actually my first post here as I only just got DP8 today with my new computer. I have been a cubase guy for a long time but I knew a lot of composers (like me) use DP and I really liked the look of it so decided to have a go.
My computer is a brand new windows i5 4690 3.5 ghz, 16gb ram, 1tb ssd beast that should be able to run a full orchestras worth of samples.
My soundcard is an Edirol ua-25, not great but it does the job and it's worked fine in the past with cubase. (just so you know I was running it at 288 samples... not that it should matter with so few instruments and processing.
I installed all my plugins and kontakt and shortly loaded up one instance of kontakt into vracks in a new project. I got up just one instrument and wacked on full articulations and mics (something even my old computer would have done easily 20 times over) and all seemed well until I tried out the MIDI editor and then pretty much every note was making the processing meter in the top right spike and with multiple notes it would crackle.
Now I'm sure I'm doing something wrong or it has to do with the whole computer, although the rest of my computer is ridiculously fast which makes it confusing. I'll be installing cubase again soon to make sure that it isn't the same on that though I'd be surprised. I guess potentially it might be a kontakt problem but I'm really not sure.
Any ideas or suggestions guys?
P.S sorry if any of that doesn't make sense, it's 3 oclock in the morning here. haha
Windows 7 64 bit
Intel Core i5-4690 3.50 Ghz
16GB 1833ghz Ram
1TB SSD
Asus Ranger VII Motherboard
16GB 1833ghz Ram
1TB SSD
Re: Ridiculously Bad Performance New Project i5 3.5ghz 16gb
One other thing is in the 'configure hardware driver' window asio is selected and asio driver is 'ua-25' (Y)
Windows 7 64 bit
16GB 1833ghz Ram
1TB SSD
16GB 1833ghz Ram
1TB SSD
DP on a Mac here but if it's anything like that, the spikes in the CPU meter and associated alert, if any, is a long time issue in DP. If it's not already disabled, disable the alert (audio prefs, I think) and if it's not creating a performance issue of any other kind (clicks and pops) just ignore the peaks.
Usually in larger or CPU intensive sequences a smaller buffer is better for tracking (recording) while a larger buffer is better while editing and mixing.
Sorry I don't have PC chops, but what I duss out from the board, DP still has a few kinks to work out on that platform.
Welcome to the board!
Thanks man but it's actually clicking and crackling when it reaches the top of the cpu meter. Just found a thread with people seeming to have similar problems, looks like DP8 isn't very well optimised for windows or something
Though still doesn't mean it's isn't something else exacerbating it (i hope )
Windows 7 64 bit
16GB 1833ghz Ram
1TB SSD
16GB 1833ghz Ram
1TB SSD
I'd call MOTU when you can. Their tech support has gotten quite good.
Mac guy here, too, but I deal with Windows on a daily basis. If this peaking only happens when you open the MIDI editor, I'd be willing to bet that there is some kind of feedback or doubling of the audio signal or MIDI data. Check your monitoring modes and Audible modes. I'd also check your Meter Bridge to see if you are getting peaks there. A good MIDI monitoring utility is a must, but I don't know of one for Windows. Anyone?
828x MacOS 14.5 M1 Studio Max 1TB 64G DP11.32
Hi there, it's not just the MIDI editor but the keyboard in kontakt, sequence and quickscribe. That being said where would I look at the 'monitoring modes or 'audible modes'? Thankscuttime wrote:Mac guy here, too, but I deal with Windows on a daily basis. If this peaking only happens when you open the MIDI editor, I'd be willing to bet that there is some kind of feedback or doubling of the audio signal or MIDI data. Check your monitoring modes and Audible modes. I'd also check your Meter Bridge to see if you are getting peaks there. A good MIDI monitoring utility is a must, but I don't know of one for Windows. Anyone?
Windows 7 64 bit
16GB 1833ghz Ram
1TB SSD
16GB 1833ghz Ram
1TB SSD
Something to add is that it (the processing meter) spikes each time there is a MIDI note played and spikes and clips every time an MIDI off note is played. Monitoring modes held no avail, and I can't seem to find audible modes. Also cannot seem to find anything suspicious in the meter bridge (though I'm not exactly sure what to look for), how would I got about finding a loop in the system?Ex-Cubase Guy wrote:Hi there, it's not just the MIDI editor but the keyboard in kontakt, sequence and quickscribe. That being said where would I look at the 'monitoring modes or 'audible modes'? Thankscuttime wrote:Mac guy here, too, but I deal with Windows on a daily basis. If this peaking only happens when you open the MIDI editor, I'd be willing to bet that there is some kind of feedback or doubling of the audio signal or MIDI data. Check your monitoring modes and Audible modes. I'd also check your Meter Bridge to see if you are getting peaks there. A good MIDI monitoring utility is a must, but I don't know of one for Windows. Anyone?
Windows 7 64 bit
16GB 1833ghz Ram
1TB SSD
16GB 1833ghz Ram
1TB SSD
If it has something to do with the audio driver, you can try using the device via ASIO4ALL rather than selecting the audio device directly. I have two audio devices that have issues with their native drivers, but work fine with ASIO4ALL as a workaround.
DP8.06 PT11.2.0 VEP 5.3.x
Hi there, yep just installed Cubase 6 again and yep, started off with the generic drivers and thought '•••• yeh! Fixed', realised i hadn't got my UA-25 (had so many problems with this card ) drivers up and then it went to •••• again.NazRat wrote:If it has something to do with the audio driver, you can try using the device via ASIO4ALL rather than selecting the audio device directly. I have two audio devices that have issues with their native drivers, but work fine with ASIO4ALL as a workaround.
Would the ASIO4ALL drivers work as well as the soundcard drivers would if they were working properly? As it would be stupid shelling all this out for a new computer just to have to use inferior drivers.
Windows 7 64 bit
16GB 1833ghz Ram
1TB SSD
16GB 1833ghz Ram
1TB SSD
In my experience sometimes ASIO4ALL performs better than the native ASIO drivers. It does some kind of blue smoke and mirrors thing with the WDM drivers. The provided drivers for the card provide both WDM and ASIO so they need to be installed. The device can be accessed in the apps either way. If you haven't used ASIO4ALL before, read the docs before you get going - short and to the point. This may or may not help, but worth a try.
Might be good to get a new audio interface...
MacBook Pro 2021 (M1 Ultra) with 64 gigs RAM. DP 11.23
