inserts added automatically
nickysnd
Post by nickysnd »
When I insert in the mixing board a plugin on the bottom slot of the inserts, DP automatically adds a new line of inserts below. Is there a way to prevent that?
Mac mini Apple M1 ♦ 8GB RAM ♦ MacOS 14.4.1 ♦ Focusrite Scarlett Solo ♦ DP 11.31
FMiguelez
Re: inserts added automatically
Post by FMiguelez »
I think there's a switch for this in the Preferences or in the mixer mini-menu.
nickysnd
Post by nickysnd »
That's what I thought too but couldn't find anything.
NazRat
Post by NazRat »
'Automatically Add Inserts' in the Mixing Board mini menu.
DP8.06 PT11.2.0 VEP 5.3.x
nickysnd
Post by nickysnd »
I don't see that in the minimenu. I'm in DP7.
Mini menu> Set number of Effect inserts. I don't think that is exactly what you want, but I think it's the best you can do in DP7.
http://www.motunation.com/forum/viewtop ... ts#p404169
philbrown
Post by philbrown »
Am I reading this right- that DP8 has an option to turn that 'feature' off?
That's been a pet peeve of mine for years.
"Set number of effect inserts" is not really a solution because it doesn't stick.
May be time to upgrade finally (I'm a late upgrader by choice).
NazRat
Post by NazRat »
philbrown wrote:Am I reading this right- that DP8 has an option to turn that 'feature' off?
Yes - the option is available in DP8.
philbrown
Post by philbrown »
Thanks NazRat - even if I had upgraded I may not have known about that.
