Hi there,
I'd like to know if it's possible to modify the velocities and other parameters in the event list at the same time on several notes. For example, I have a staccato passage where I'd like an accent on certain downbeats. I could use the set velocity command, but I'd like to be able as well, for example, to do that in the even list window, by dragging up and down the velocity value on multiple notes.
Thanks in advance for your help!
Ziobello
Editing multiple velocities by dragging in the event list
- Dan Worley
Re: Editing multiple velocities by dragging in the event lis
No, that's not possible. You already found the best way. Select the notes and use Set Velocity.
DP10.13
