DP8.06 Paste Repeat does Merge Repeat? corrected
frankf
Post by frankf »
In SE or GE in DP8.06, when using Paste Repeat in a single track, the data in the clipboard does NOT overwrite existing track data, it merges the data as if the Merge Repeat command was invoked. Every time here. Can someone confirm this? Thanks.
Frank Ferrucci
http://www.ferruccimusic.com
doodles
Re: DP8.06 Paste Multiple does Merge Multiple?
Post by doodles »
not sure what you mean by paste multiple?
Just tried copying and pasting in TO window. 4 bars in 4 tracks, then pasted them into bars 3-5. Overwrites here...
2*5-core 3.46 Intel xeon (32 gigs RAM), 2*dual 2.5 (16 & 32 gigs RAM), DP 8.07, WAVES 9, Lexicon plugs, SoundToys, all Spectrasonics, NI Komplete 9, Vienna Ensemble (extended), LASS, Evolve, Symphobia, etc, Cinesamples, Arturia, cinestrings, all Project Sam
NazRat
Post by NazRat »
doodles wrote:not sure what you mean by paste multiple?
If you hold the option key and click on the Edit menu you will see all the 'Multiple' paste/merge with their key commands.
DP8.06 PT11.2.0 VEP 5.3.x
frankf
Re: DP8.06 Paste Repeat does Merge Repeat?
Post by frankf »
My mistake, the command I was referring to is Edit>Paste Repeat not Paste Multiple. I'll have to test Paste Multiple. Sorry about the confusion.
Frank Ferrucci
dix
Re: DP8.06 Paste Repeat does Merge Repeat? corrected
Post by dix »
I've noticed this too ever since DP8 showed up. I think it's a bit more useful like this, but having the option to paste would be nice.
wilcofan
Post by wilcofan »
Confirmed. I have one bar copied and use "paste repeat" having selected the next 7 bars.
Only the first bar is replaced. The next 6 are merged.
I'm new to Digital Performer as of DP8 so I wasn't sure it was a bug. However, if I wanted the behavior it is doing, I would have used "merge repeat".
According to the manual. (which states "paste" always replaces)
Digital Performer 8.07
Mac Pro 3.1
Windows 7 (bootcamp)
