Ultralite Mk3 Hybrid not recognized by MBP Mid 2012
FlatEric
Post by FlatEric »
Hi there,
Yesterday I spent the whole day trying to install my new Ultralite MK3 Hybrid into my MacbookPro 2012, but couldnt achieve that :|
I connect it via USB port, so using also the dc power supply.
Nothing happened. Seems like the interface its not detected by the mbp.
In fact, when I open AudioDesk, it appears:
"No audio hardware was found. [MotuAudioSystem Mas MasCoreAudioDeviceSet.cpp 139 [58:0]"
At the Ultralite LCD screen I can read how it initializes:
Loading AutoRoute....Done
Loading Cue Mix.... (then a kind of snap or click sounds)
Meter 48 (blinkin a couple of times and keeps on the screen).
If I open CueMix FX, the "Devices" tab is empty.
If I open Motu Audio Setup, I can not see the Ultralite mk3 installed.
It does the same start either if its connected to the laptop or not, nothing seems to be different in both cases.
I dont know what more may I try.
Of course I've download the lastest drivers from the official website, I've also updated my Mac OsX (used to have 10.4.8 and now 10.9.2, doesnt work in both versions).
My MBP is a mid2012 with an i7 @ 2.9 Ghz, 8GB DDR3, SSD of 256GB and two USB 3.0 ports.
I hope someone can help me. I'm a bit frustrated with this issue.
Thank you for your time.
Kind Regards,
A.
Re: Ultralite Mk3 Hybrid not recognized by MBP Mid 2012
If nobody has an answer, I'd consider calling MOTU tech support Monday morning.
Oddly enough there's another brand new user posting about a similar problem with the Ultralite here:
http://www.motunation.com/forum/viewtop ... =1&t=57402
Quite the coincidence. You might want to look in that thread and see if a solution comes up there as well.
FlatEric
Post by FlatEric »
Yes, I've read it. It's quite similar, but that user said he had the interface running for a short period of time, and then it crashes. I've never got it recognized.
It's quite strange, I've read many threads talking about these kind ofnot-recognizing-problems. Is there any known issue between mbp usb 3.0 ports and Motu usb 2.0 interfaces? Is it supposed to be recognized just plugging it? Maybe the interface (as it works as standalone unit) is by default not connecting the usb data feature?
So many questions...hope someone could help me.
Regards.
FlatEric wrote:Yes, I've read it. It's quite similar, but that user said he had the interface running for a short period of time, and then it crashes. I've never got it recognized.
Regards.
I think I may have heard of some people having to use USB hubs between them. Not sure.
Check out this topic:
http://www.motunation.com/forum/viewtop ... =1&t=54092
I think in some cases using a hub in between helped.
FlatEric
Post by FlatEric »
Well, we will see.
I've written several emails to motu support, but their costumer service really sucks.
After 6 days no answer, and when I try to register the product with the serial number, webpage says serial number doesn't match with product selected.
Even last friday the webpage was the whole day down.
Really dissaponted with them.
Agent of Random
Post by Agent of Random »
I had the same reg problem with the 828 hybrid...turns out I had the regular mk3 version selected instead of the Hybrid, so thats why my serial woudnt go through. Maybe youre having the same problem?
Anyway you can contact support directly once you registered, so that or calling is probably your best next move
You have swapped cables, right?
The usb and FW ports can get corrupted. Certain brands of FW hubs have been known to cause this problem.
Reset your NVRAM (PRAM). Shut down and hold the Option-Command-P-R keys while booting. Let it chime 3 times before releasing. I once had to do this three times with AppleCare Support on the phone before my ports came back to life. Support was getting ready to schedule a service call to replace the motherboard.
Use Apple Disk Utility to Repair Permissions. Also run Verify Disk. If it reveals any problems, run Repair Disk from another drive.
