No Track Selector in 'popped out' Mixer. SOLVED
NazRat
Post by NazRat »
In DP 8.06 on the Mac I can't get a track selector in a 'popped out' mixer or sequence window. Every time I click the button in the lower left corner of the independent mixer or sequence window to open/close the selector, the track selector in the Consolidated window opens/closes. Anyone else seeing this? I checked on the PC and behavior is as expected - the independent mixer/sequence window has its own track selector. Maybe a preference, but just not seeing it.
DP8.06 PT11.2.0 VEP 5.3.x
frankf
Re: No Track Selector in 'popped out' Mixer.
Post by frankf »
Not in front of DP, but there' s a preference for this
Frank Ferrucci
Frank Ferrucci
http://www.ferruccimusic.com
NazRat
Post by NazRat »
The only preference I can find is to open the Track Selector inside the Consolidated window. What this does is either open it the Consolidated window or float it. I want to open the 'sidebar' track selector of an independent mix or sequence window. Here's a screen shot from the PC:
Can't get that sidebar open on the Mac. It was available in previous Mac versions. Thanks.
Dan Worley
Post by Dan Worley »
Assuming it will work with how you have other preferences set, this needs to be turned on to achieve what you want:
Preferences : Editing : Track Selector button : Opens Track Selector window for editors inside Consolidated Windows.
Oh, sorry, I see this is what you were just talking about (Duh!).
It works here, just so you know.
DP10.13
NazRat
Post by NazRat »
Deleted DP preferences and now working again.
