I am having difficulty setting up my MOTU 828 MKII to send the digital channels to my RME Fireface 800 via ADAT (Windows 7 - 64 Bit with latest driver installed for both units.)
The problem is showing symptoms via the following:
Whenever word clock is set to external 44/48.
1) Motu shows flashing 44.1 Khz on front panel.
2) It will not show the analog input signal on front panel either.
3) With firewire plugged in, Cue Mix cannot set buses to ADAT out, They switch back to blank after couple of seconds.
Whenever word clock is set to internal 48 Khz.
1) Motu Shows solid 48 khz on front panel.
2) It shows the analog input signal fine on front panel.
3) Whith firewire plugged in, Cue Mix can set buses to ADAT out and they stay selected until setting word clock back to external.
Setup:
I have my optical ADAT cable coming out of the Motu to the input of the RME.
I have a coaxial wordclock cable coming out of the RME to the input of the Motu.
My software is configured as pictured below:
The RME Mixing software shows I am getting a bunch of static/clicks at the input instead of proper signal, it says "phones", but is the ADAT in.
Any help would be greatly appreciated. I am pulling out what is left of my hair!
Cheers,
Court
