Play Enable RESOLVED
Hello!
A friend and I are sharing a project, and I'm having a bit of difficulty soloing tracks.
To clarify:
I CAN solo a singular track prior to playback. However, upon playback, several other tracks automatically become play enabled. It's as if they are somehow grouped. Is there a place to look for groupings or might he have done something to cause other tracks to play? There are no solo exempted tracks.
To clarify:
DP 11.31, Mac Studio M2 Ultra, 128GB Memory, Sonoma 14.3.1
- Dan Worley
Re: Play Enable
Hit Option-Shift-G to open the Track Groups window. If there are any groups they will be listed there and you can enable/disable, edit or delete them.
Solo can be grouped.
DP10.13
Re: Play Enable
Did the Option-Shift-G suggestion. The Project shows no Groupings.
Thoughts?
Thoughts?
Re: Play Enable
Any chance there's automation embedded in the tracks?Aaron Guidry wrote:I CAN solo a singular track prior to playback. However, upon playback, several other tracks automatically become play enabled. It's as if they are somehow grouped. Is there a place to look for groupings or might he have done something to cause other tracks to play? There are no solo exempted tracks.
Re: Play Enable
Ahhh! Riddle solved! Thanks!!James Steele wrote: Any chance there's automation embedded in the tracks?
Re: Play Enable
Ha! Glad I got lucky on that one!
