We have an 896mk3 that we're trying to use to switch from Analog Mixers that are dying to Digital. All of the XLR Inputs have Microphones and all of the XLR outputs go in pairs to the AMPs as well as one of the digital outputs to an audio recorder and FM broadcaster. It is live audio in an arena.
These are amateur presenters, and sometimes MICs that are not in use will be moved/handled while another MIC is live. So...... we need to be able to adjust the Volume of the individual MICs on the fly to all of the outputs (re: turn them to 0, or turn them up/down based on who's talking and how loud they talk, etc.). Unfortunately, if I'm understanding CueMix properly, adjusting the volume on the "Mixes" tab only effects the output pair assigned to that Bus? It was suggested we instead use the Inputs tab and use the trim knob as a volume if we want to affect all output simultaneously, which seems to work, except, trying to adjust that knob on the fly is not always easy and remembering the proper spot to twist it to is not easy either.
