automation problem w/ dp 4.6
lorne1200
Post by lorne1200 »
I have recently installed dp 4.6 and its working fine
except, I've just encountered a problem when i attempt
to edit the automation on any particular effect in the
sequence window. Its a little weird, as it allows me
to edit volume + pan automation. but when I attempt
to edit effects automation everythings greyed out and
i cant see automation events happen eventhough I can
hear them happen. Am I missing an extra step here? I
wasn't having this problem in 4.5. So if somebody out
there could navigate me thru this little dilemma I
would be very thankful
Best,
Lorne
...it's yours!
npatton
Post by npatton »
I could be way off, but might this have anything to do with the View Filter? Manual pg 432. If not, oh well...
n
studiodog
Post by studiodog »
Or try Page 691 if that doesn't work. I suspect that page holds the answer.
lorne1200
Post by lorne1200 »
A million thanks to you "npatton" + "studiodog" for your assistance. My problem was located in the view filter as you suggested. Everything is cool now----THANK YOU BOTH!
...it's yours!
oointerrupt
Automation issues
Post by oointerrupt »
I had the same issues, thanks to this site, I figured it out.
Just wanted to thanks all. :P
