I felt I should address this as a long time Logic and DP user.
daveyboy wrote:Having bought Logic this year some things that drive me crazy are:
1)No multiple takes per track, you have to make a new track in order to do a new take.
No but there is a way to auto generate tracks on cycle record and a simple SHIFT-RETURN will create a new tack with the same settings. It is just a different way of working. I think SX has the best solution here.
2)No multiple mixes. You have to save your file under a new name in order to keep your mixes organized.
You are correct here but that is hardly a show stopper.
3) You need a special tool to do any audio editing plus there's a limit on the zoom of the waveform, very clunky.
All the way to sample level is a limit? How close do you need to get? What tool are you referring to to do editing? The curser automatically changes depending where on the object it is pointed. I like the fade handles in DP better but otherwise both achieve the same level of editing.
4) Can't process individual soundbites with a plugin without doing a bounce to disk.
5) No trim function on the mixer.
True for #4 but there is a key command to open external wave editor and works quite well. As for #5 there are other ways to increase gain if that is what you are after. Maybe I am not understanding what you mean.
6) To access a multitimbral VI such as Kontakt takes a little work in the environment to get it setup. To automate volume and pan takes even more work in the environment. In DP it's a now brainer.
Correct and incorrect. You can either simply just set the channel to ALL for the track with the Kontakt plugin and change the channel of your controller or yes you do have to go to the environment. Once it is set up is is a breeze. (The other method is easier).
There is nothing that has to be set up in the environment to do automation in Logic. It is a simple as switching on the automation. It is just as easy as DP here.
In the end they both are fantastic apps. DP's included pitch correction is great and there are other things that make it nice and other things that will piss you off.
What someone (I think from this forum) once said is that before yo switch apps try learning about something that you didn't know your current app could do. I can't tell you how helpful the tips here have been and all the Logic things I have learned over time. Every week or so there is something else that is discovered.
Of course you could be like those of use with both!
Chris
