Cannot authorize IK CSR in 32 Lives under Mavericks
I've now burned 4 out of the 5 authorizations IK gives me for Classik Studio Reverb and I cannot get it to authorize in DP 8.05 running in 32 Lives in Mavericks. I've downloaded and ran IK's new Authorization Manager app and it says it's authorized and I still get the demo warning dialog when I open the instance of CSR in a project. Arghh... :(
emulatorloo
Re: Cannot authorize IK CSR in 32 Lives under Mavericks
Post by emulatorloo »
On edit: after second cup of coffee, understood your issue better, so deleted my reply.
James Steele wrote:I've now burned 4 out of the 5 authorizations IK gives me for Classik Studio Reverb and I cannot get it to authorize in DP 8.05 running in 32 Lives in Mavericks. I've downloaded and ran IK's new Authorization Manager app and it says it's authorized and I still get the demo warning dialog when I open the instance of CSR in a project. Arghh... :(
But wasn't CSR updated to 64 bits last year? Why run it in 32 lives?
Actually I got a response from IK. You have to run the new 64bit TrackS Custom Shop or whatever and then use "Restore My Gear" and it will let you use those modules in it. I still have a problem though with my original TrackS 1 modules. Only the EQ is available to me and not the rest if the suite. I can't authorize with 32 Lives and Mavericks. I think I *might* be able to authorize with jBridgeM and Mavericks. Haven't tried. My CSR issue is resolved, but now I have to get TrackS 1 working. Although not as big a deal now that I use Slate FG-X so much these days.
I'm pretty sure my T-Racks modules were all updated to 64 bit (for free) at the same time the CRS 64 bit update happened, and that they run without the T-Racks shell in DP 8. I'll check next time I'm on the system.
csavetman
Post by csavetman »
CSR does run in DP8 without the shell. I can confirm this.
Yes, it always did. But do the other T-Racks modules also run standalone?
David Polich
Post by David Polich »
bayswater wrote:Yes, it always did. But do the other T-Racks modules also run standalone?
Yes they do.
http://www.davepolich.com
csavetman wrote:CSR does run in DP8 without the shell. I can confirm this.
Well right... it's a "single" or whatever they call it. It will be called "T-RackS CS CSR Plate.component" in the Components folder.
