Processor meter bouncing and over 50%
Re: Processor meter bouncing and over 50%
Thanks. It looks good from here. Bueller? Bueller?
828x MacOS 14.7.6 M1 Studio Max 1TB 64G DP11.34
I'm getting crash on quit with DP
here's a couple of logs ... I'm not good at finding crash logs but here's what i found
maybe something to do with Finale?...
1
Process: mdworker32 [712]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker32
Identifier: mdworker32
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: launchd [1]
PlugIn Path: /Library/Spotlight/Finale.mdimporter/Contents/MacOS/Finale
PlugIn Identifier: com.makemusic.MDImporter.Finale
PlugIn Version: 2.0 (1.1)
Date/Time: 2014-02-02 08:58:27.740 -0800
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000013ee8ffc
Crashed Thread: 3
Thread 3 Crashed:
0 libSystem.B.dylib 0xffff0f20 __memcpy + 1920
1 com.apple.CoreFoundation 0x9798bb34 CFStringAppend + 340
2 ...makemusic.MDImporter.Finale 0x03885eef TextChunkExportToSpotlightData::Call(short, short) + 335
3 ...makemusic.MDImporter.Finale 0x03888fc9 TextChunkBaseClass::CycleThroughAllTextChunks(short) + 55
4 ...makemusic.MDImporter.Finale 0x03889011 TextChunkBaseClass::CycleThroughAllTextChunks() + 25
5 ...makemusic.MDImporter.Finale 0x038890e4 ExportToSpotlight_Lyrics(__CFDictionary*) + 76
6 ...makemusic.MDImporter.Finale 0x03daa5b2 FXP_ExportToSpotlight + 1432
7 ...makemusic.MDImporter.Finale 0x03dabbfe GetMetadataForFile + 126
8 mdworker32 0x00007a67 0x1000 + 27239
9 mdworker32 0x0000b641 0x1000 + 42561
10 libSystem.B.dylib 0x96bc9259 _pthread_start + 345
11 libSystem.B.dylib 0x96bc90de thread_start + 34
2
Process: mdworker32 [704]
Version: ??? (???)
Date/Time: 2014-02-02 08:58:16.872 -0800
Report Version: 6
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000010727ffc
Crashed Thread: 2
Thread 2 Crashed:
2 ...makemusic.MDImporter.Finale 0x04085eef TextChunkExportToSpotlightData::Call(short, short) + 335
3 ...makemusic.MDImporter.Finale 0x04088fc9 TextChunkBaseClass::CycleThroughAllTextChunks(short) + 55
4 ...makemusic.MDImporter.Finale 0x04089011 TextChunkBaseClass::CycleThroughAllTextChunks() + 25
5 ...makemusic.MDImporter.Finale 0x040890e4 ExportToSpotlight_Lyrics(__CFDictionary*) + 76
6 ...makemusic.MDImporter.Finale 0x045aa5b2 FXP_ExportToSpotlight + 1432
7 ...makemusic.MDImporter.Finale 0x045abbfe GetMetadataForFile + 126
Thread 2 crashed with X86 Thread State (32-bit):
eax: 0xffff07a0 ebx: 0x00000000 ecx: 0x00000000 edx: 0x1054ae40
edi: 0x1fb58000 esi: 0x001dd1fc ebp: 0xb0183098 esp: 0xb0183090
ss: 0x0000001f efl: 0x00010202 eip: 0xffff0f20 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
cr2: 0x10727ffc
There's 2 more but I don't want to post too much info
1
Version: ??? (???)
Report Version: 6
Crashed Thread: 3
Thread 3 Crashed:
2
Version: ??? (???)
Report Version: 6
Crashed Thread: 2
Thread 2 Crashed:
cr2: 0x10727ffc
Ok ... I think I'm getting somewhere...
just ran the Apple Hardware Test and got an error returned ... coded
4MEM/40/40000001 : B:O:C:1 R:3
Anyone have any clues what this means?
Yes. MUCH information here.
You don't think i tried that? If these posts are wasting your time but you have enough time to "Let Me Google That For You" ... your wasting your non-wastable time.MIDI Life Crisis wrote:Yes. MUCH information here.
People use forums AFTER google and try to go right to the source of good info from the members of forums like these.
You asked. I answered. You're welcome.
Last edited by MIDI Life Crisis on Sun Feb 02, 2014 7:50 pm, edited 1 time in total.
- daniel.sneed
Disabling the V-rack hosting a master fader with Ozone makes huge difference here too.
I turn it on only when buffer is maxed.
It's my basic tracking/mixing strategy.
BTW, I've seen that closing, or hiding, unnecessary windows will free some CPU, sometimes in a dramatic way.
I highly recommend experimenting around this.
dAn Shakin' all over!
It's faulty RAM.
First off, thank you all for the helpful responses. It's much appreciated and I'm glad there's people here willing to actually help.
After Hardware tests, here are my results
Add RAM installed (2x4GBstick, 2x2GB sticks, and 2x512MB sticks)
AHT Results: error 4MEM/40/40000001 : B:0 C:1 R:3
2x4GB and 2x2GB RAM sticks installed
AHT results: error 4MEM/40/40000001 : B:0 C:1 R:3 (same as above)
2x2GB sticks only
AHT results: error 4MEM/40/40000001 : B:0 C:0 R:1
2x4GB sticks only
AHT results: error 4SNS /1/ 40000001 : VMBS
The only thing I haven't done is test ONLY the 512MB RAM sticks but seeing how I'm getting error codes on all tests, I imagine I'll get the same.
But here's my quandry, the iStat menu shows the Memory under QUADRO FX 4500 as pinned. Could this be a Video Card issue? Could the Video Card be causing the processor spikes and all these issues?
I appreciate ALL the help!!
2x2GB sticks only
2x4GB sticks only
Hi,
I have the same problem since upgrading to Mavericks. I found out though that the cause is a Bud receiving from a Rewire output (in my case Sibelius).
When I disable the Rewire Track everything goes back to normal.
I hope this helps.
Take care.
Andrea
I hope this helps.
Take care.
Andrea
I'm not exactly sure what that means ... but when I do look at my crash reports i do see Finale listed in the crashed threads. something about the mdImporter.pejobass wrote:Hi,
I hope this helps.
Take care.
Andrea
With your issue, was your GPU Memory meter pinned like mine is?
Let's see... How many posts in this thread and you still haven't mentioned which version of Finale you have?
More than once, when you have had problems, I have suggested that you post a hardware and software profile. You still have yet to do so - I mean one that tells anyone else what you have.
In this case, I know what you're problem is. It's fairly well known, actually. Without a detailed profile, I can't tell you how to fix it. You see, the installed versions that you have of certain software tells someone like me where you should look for the offending culprit. It makes a difference.
The only helpful info you have received in this thread was from MLC when he suggested a Google search. Everyone else is guessing.
Yes....maybe something to do with Finale?...
I'm just trying to fix my DP issue and computer. I'm not trying to waste anyone's time. This could be a mixture of a myriad of issues and I'm trying to single it down to one or two. After extensive research and trying to narrow down the troubleshooting, I mentioned possibly a Finale mdImporter file being an issue.mikehalloran wrote:Let's see... How many posts in this thread and you still haven't mentioned which version of Finale you have?
More than once, when you have had problems, I have suggested that you post a hardware and software profile. You still have yet to do so.
In this case, I know what you're problem is. It's fairly well known, actually. Without a detailed profile, I can't tell you how to fix it. You see, the versions that you have of certain software tells someone like me where you should look for the offending culprit. It makes a difference.
I have Finale 2011r2 and Finale 2012rc2 on my machine.
I appreciate your insight and suggestions. I apologize for not following your comment as it may have slipped through my routine of troubleshooting for 10 hours straight.
re: posting a hardware and software profile, I'm not sure how to do so. Looking at my Software profile in my system profiler, I have Finale 2003 through 2007 on a separate drive (used to boot up an old system OS 10.5.
I have Finale 11 and 12 on my current system drive.
I'd be glad to post Hardware and Software information if it'll help. I have been Googling and researching and even on the phone with Apple Specialists.
I appreciate, again, all the help.
This has been going on since at least Jan 16 and it's now Feb 2 and have you contacted MOTU?
Last edited by MIDI Life Crisis on Sun Feb 02, 2014 7:51 pm, edited 1 time in total.
Love and Peace to all. I'm just trying to get help. I'm sorry if I've upset anyone and I'm sorry this has resorted to childish name calling and jabs. I don't wish to partake in such behavior.
I just want to make music and try and have peace with everyone. I'm sorry if I'm not as advanced in my computer knowledge as some/most people so forgive my ignorance.
I do appreciate all the help thus far and appreciate any more insight.
I'm running memtest right now. It's taking a while but hopefully that might give some answers.
