DP Exhibiting Odd Behavior
mpeluso
Post by mpeluso »
Hello all. Having a weird issue here. I'm running DP 8.05 with Stylus (up to date, can't recall the version number as of now) and using VE Pro (ver. 5.1.12684) to host samples inside Kontakt 5.3 in two external Mac Pro's. The issue that seems to keep occurring is a random overhang of a few patches in one of the external Mac Pro's, and Stylus will randomly start up where there is no MIDI data (mostly happens at the beginning of a chunk). I don't believe this is a VE Pro issue, nor do I think Stylus is suspect, as this setup has been extremely solid for months now. Anyone have a similar experience with this setup? Any help would be very much appreciated!
DAW: Mac Pro 3.33 Ghz i7 Hex Core / 32GB DDR3 RAM OS 10.8, DP 8.01
Slave: 2.66 Ghz i7-920 Quad Core / 24GB DDR3 RAM, Windows 7, Kontakt 5, Spectrasonics, VEPro 5
mpeluso
Re: DP Exhibiting Odd Behavior
Post by mpeluso »
Well I've discovered there is a bug with DP 8.05 where you have to leave the Stylus GUI open underneath DP or it will trigger wildly. Can't figure out the other goings on.
Thanks for the report and follow up.
Kubi
Post by Kubi »
what OS?
Kubi
Kubilay Uner
http://kubilayuner.com
MacPro 2x2.8 GHz Quad-Core Intel Xeon, 20GB RAM; OS 10.9.5; DP9.01; MOTU 2408mk3 & MIDI Express 128 w/latest drivers
mpeluso
Post by mpeluso »
Oh, forgot to mention that. Mac OS 10.8.
theaks2002
Post by theaks2002 »
I have noticed with OS 10.8.5 (and even Snow Leopard) and DP 7.4.. that you need to keep VI windows open (or collapsed in dock) in order to have them react to volume changes in the mixer.
Has this been addressed in DP 8 or same issue?
mpeluso
Post by mpeluso »
I've only experienced it with Stylus. Then again, that's the only VI that I use inside of DP.
