I'm running a 2011 Mac Pro with a 2408, DP8, OS 10.8, etc.
Over the years I've tried adding PCI/e cards for external storage. First it was esata which was unreliable and more recently I tried USB3 which caused immense kernel panics. It's looking like my Firewire 800 ports are going, so I was tempted to try Firewire 800 next, but wanted to see if anybody has luck with the 2408 and a specific card?
Many thanks for the help!
MacPro 2011 *upgraded* 12 Core 3.33. 64 Gigs RAM. 2x PCIe SSDs, 2x SATA SSDS - OS 10.10.5, DP9.02, VEP5 + VEP5 Slave PC (i7)
Both eSATA and usb 3 cards are pretty reliable nowadays. eSATA is extremely sensitive to cable movement or bad cables.
Kernel panics shouldn't be happening unless there were incompatible drivers or firmware. I'd buy from a vendor that knows Macs such as OWC and can provide support.
Although speed will increase, especially with SSDs, you are limited to the data bus of the PCIe. With mechanical drives, the platter speed is your bottleneck - for that reason, there is no speed difference between the two protocols.
If you are using SSDs, usb 3 which has a higher potential throughput.
DP 11.34; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1 2023 Mac Studio M2 8TB, 192GB RAM, OS Sequoia 15.4, USB4 8TB externals, Neumann MT48, M-Audio AIR 192|14, Mackie ProFxv3, Zoom F3 & UAC 232 32bit float recorder & interface; 2012 MBPs (x2) Catalina, Mojave IK-NI-Izotope-PSP-Garritan-Antares, LogicPro X, Finale 27.4, Dorico 5, Notion 6, Overture 5, TwistedWave, DSP-Q 5, SmartScore64 NE Pro, Toast 20 Pro
