MIDI Life Crisis wrote:
The o/p has this idea that changing presets in a plug 50 or 60 times in a sequence is a good idea (it's not).
Respectfully, I disagree.
Perhaps 60 tracks is a bit extreme, but I can think of a couple of situations where doing that might be just the ticket. For instance, for mastering a custom music library, where you can have many short pieces, this could be done very effectively.
The manual has a case study detailing precisely this workflow.
ToBeJazz wrote:Unfortunately having multiple tracks or plug-in instances is not an option here since I need to have many presets to go between, app. 40 presets.
Having a plug-in with about 25 parameters makes it very inefficient to have to automate and change all those parameters instead of just being able to load a preset.
I fail to see what the problem is. Look at that section of the manual I mentioned (I think it's in the snapshots section).
Basically, leave the Automation Setup window opened. Select the range of one soundbite (or any region). Tweak to taste. Then, simply take an all-parameter snapshot for this region only (look at the options offered by the snapshot command). Go to the next section and repeat...
Doing this with a combination of enabling and disabling plug-in automation is key (via the Automation Setup window). This way, no matter how many parameters there are, each section will be automated and played correctly.
Changing any setting is as easy as placing the cursor anywhere in between previously taken automation points, optionally disabling automation, tweaking, and retaking the snapshot. Bam! Done in 0.5 seconds with shortcuts.
Putting markers at the beginning of each of these sections would expedite navigation enormously (this can be done very quickly too!)
You normally wouldn't need to edit any of these parameters individually, if that's what worries you. You can treat all this as "brute" sections of automation which can be set very precisely with this coarse method.
Also, Dan's suggested workflow sounds interesting too. You should definitely try doing that as well.
I do agree with MLC that you need to tell us what you're trying to do if you want useful help...
