Unfortunately, I'm trying to resurrect a session from about 15 years ago by transferring some audio back to DP.
I have the original sequence, but I no longer own over half of the modules that were used to create this track and the transfer to the DA-88 tapes.
The session is on 3 tapes. I successfully transferred the piano track then switched tapes to transfer some chordal string beds.
About 2/3 of the way through, I noticed 2 dropouts on all 8 tracks (even though at that particular moment I was only interested in the 2). I rewinded and tried again. Same spots.
Somehow, I actually found the Head Cleaner and put the machine into Cleaning Mode but it appears that this cassette is either used up or defective as the machine kicks it out after about 5 seconds...should be about 15.
I have a studio friend that is going to loan me his head cleaner tape which I'll try but I think I know the answer to this question...
If the dropouts and error light are coming at the same 2 spots with each attempt, I believe I can assume that the tape itself is somehow damaged?
Merci...
Buzzy
DA-88 Tape (Remember those!?) Dropouts
- buzzsmith
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
Re: DA-88 Tape (Remember those!?) Dropouts
I've had two DAT machines go out like that and bought a used one that is marginally better. In my case (and perhaps in yours) the heads get out of alignment very easily and digital is very unforgiving in that regard.
- Gravity Jim
I used to work on DA-88s synched to Performer, and would frequently carry a machine to an Indianapolis studio to record group vocals with a really hot pop quartet down there... rough mix of the track on two tracks, fill up the other six with the singers.
Before I sold my last machine, I thought it might be fun to transfer those vocals into DP versions of the old Performer files and experienced exactly the same problem, with DA cassettes that had been stored, unplayed, in a very stable climate away from heat or sunlight. While it was more stable than ADAT, those cassettes just don't last, and when enough data fades away to comfuse the 88's extrapolation algos, then all 8 tracks drop-out and the tape is toast. I saved about half the material. The rest... well, it's a good thing nobody will ever want those tracks remixed.
Jim Bordner
If it is minor dropouts where error correction is doing a bit too much, RX-2 or 3 (especially Advanced) can do wonders - it won't recreate the original wave but it can get closer than you think. If the tapes are too far gone for the machine to lock up, I have no useful suggestions.
Maybe it's not such a tragedy all my ADAT tapes burned up in 2003...
- Shooshie
Ouch!HCMarkus wrote:Maybe it's not such a tragedy all my ADAT tapes burned up in 2003...
Tragedy or no, still ouch!
Shoosh
