dp closing down after loading project
- scott dansby
I am having trouble loading a project that has been saved. Last night I opened it and everything worked fine, but today the project loads up but doesn't let me do anything before shutting down. Other projects are loading. This is the only one that is not loading. Very, very frustrating. What should I do?
My DP brain saw what Scott D. typed and just assumed he meant he was "Loading" the file as Azusa recommended.azusa749a wrote:Try changing the name or open a new project and load the trouble one.
This is good advice from Azusa, create a new file and select "load" from the main DP menu. Loading a file into a fresh new one will solve lots of problems.
Never tried the "changing the name" thing though. Does that help problem files?
Try this...
Create a new project.
Load all soundbites, chunks etc...
Close the project
Open the old "corrupt" project
I've done this on several projects that wouldn't open as well as projects that were giving me a "-199" error....
Close the project
2.66 Mac Pro, 10.6.5, 16 G RAM, DP 7.22, 6 SATA internal drives (2 RAIDS & 2 singles), Ozone 4, 2 UAD 2 Quad card with most of the plugs, Waves Diamond(V7), V- Series (V6) & SSL4000(V7), PLAY 1.25, EMI TG12413, URS CSPro, Autotune Evo, Scarbee KGB, EWQLSO Platinum Pro XP, Drumagog, BFD2, NI Komplete 7, Breverb, Ivory w/ Italian Grand, USB Plugsound Pro & Synths Anth, Ampeg SVX, Amplitube3 (And Fender), Altiverb, Melodyne, MOTU 24 I/O with Black Lion Mod.
Are there any VIs or plugins installed in the project. These are the culprit 99% of the time. Especially Sampletank or SonikSynth2.
Remove these components to open this project if this is the case. There are known issues w/ DP4.6 and Sampletank 2 XL and SonikSynth2. Seems to be only the XL versions though...hmmm...
Dual 2.0, OS 10.4.3, DP4.52, MOTU 828 MKII, IK Plugs, Plugsound, Mach 5, Waves 5.0.
