sound on Steve Winwood's "Valerie"
- KarlSutton
I'm not up on my synth history too much, what was the synth he used for the lead on that tune? Is there a way to emulate that with mx4?
I'm not up on Steve Winwood tracks, but after listening to it, the entire thing seems pretty synth-drenched. If you're referring specifically to the lead sound, I'll bet two doughnuts that the lead sound is the tried and true minimoog.
Pull up a default patch.
Change the wavetable of an active osc to 'vintage mini' and slide the wavetable index all the way to the right so the waveform looks like a narrow pulse.
Enable a 24dB low pass filter. Pull the filter cutoff to about 44 semitones.
Add some resonance - about .33
Set amp release to about 130ms
Set mode to legato, add a little portamento
If you like, enable stereo, and stereo detune and a little delay.
That should get you most of the way there.
- BradLyons
- Primary DAW OS: Windows
Hmmmm would be interesting to know. Years ago from "Mike and the Mechanics" on "All I need is a Miracle", I swore the sound was from a DX7. In a conversation I had with Adrian Lee back in ooooh 1998 or so, he said it was an SH101! Yeah, I was way off
Thank you,
Brad Lyons
db AUDIO & VIDEO
-Systems Advisor, CTS
Brad Lyons
db AUDIO & VIDEO
