Issue with 32 Lives and DP 8.05
Re: Issue with 32 Lives and DP 8.05
+1 for Bidule.
iMac 2.7Ghz quadcore i5 16 gig RAM DP 7.24 OS 10.6.8, iMac G5 2.1GHz 2.5 gig Ram DP 5.13 OS 10.4.11 MOTU 828 MK2, East West Platinum Plus, Miroslav Philharmonic, Komplete 5, Kontakt 2 Garritan Big Band, Mr Sax T, The Trumpet, DrumCore, Trilogy and Trillian, Ivory, MachFive, Ethno Instrument, Reason 4, SampleTank 2 Sampletron, Samplemoog, Melodyne Editor, Nomad plugins, Vintage Warmer, Ozone 4, Amplitube Jimi, Xgear and AmpegSVX.
http:www.davidosuna.com
- daniel.sneed
As James already stated, 32Lives takes care of Miroslav Philharmonik in DP 64bit.
Great point in my projects!
dAn Shakin' all over!
Yeah... but it's a no-go for Altiverb 6. I wrote the 32 Lives developer and he said Altiberb support broke in the last version. I just cant afford to fork out $200+ for the Altiverb 7 upgrade right now.daniel.sneed wrote:As James already stated, 32Lives takes care of Miroslav Philharmonik in DP 64bit.
- cloudsplitter
32 lives issued an update yesterday....
Mac Pro 3,1 8 core 12 gigs ram Mavericks. DP-8.05 Fractal Audio Axe-FX Ultra, motu traveler, motu MIDI express, 2-24" LCD monitors, Yamaha HS80M,Yamaha NS10M's JBL28P monitors. Mackie control universal, BFD-2, Omnisphere,Trilian Ozone 4, Melodyne Studio/Editor, . Alesis Masterlink. Avalon 737sp. PCM 90. MikTek C4V. Korg Triton Extreme. Paul Reed Smith guitars, MPC-2500 there's more..but that's the heart of it.
Yep. I got the newest version. There are a couple of topics going on about bridging. I'm still experimenting. I've been trying to arrive at something stable. I've been leaning toward jBridgeM for most things, but need to make a project that is either ONLY 32 Lives or ONLY jBridgeM to really ascertain the stability of each as it's hard to tell which is to blame if there's a crash with both running in the background.
Although it's not as polished, I like the fact that jBridgeM gives the user more options on how it treats each plug-in. The "Performance Mode" for instance lessens the CPU hit of Slate FG-X considerably—although soon as Slate releases the 64-bit AU this will be a moot point.
One issue of particular interest to me is which of the two bridging solutions here handles Liquid Mix better. I had an issue with meters on the Liquid Mix hardware not updating during playback after updating my Mac to Mavericks. I solved this by disabling the new "App Nap" feature in Mavericks on the Liquid Mix app and jBridgeM's "auxhost" app, by doing a "Get Info" on each and checking the "Prevent App Nap" option.
I stress that I haven't fully investigated 32 Lives properly, but now that there's a fix for Altiverb 6 supposedly, I'll give it a try. If the upgrade fee to go to Altiverb 7 were say $79 or something like that, instead of $215, I wouldn't even bother... but that's another issue. If AudioEase has a sale, perhaps then I'll forget wrapping Altiverb 6.
Oh and I still have an issue with a old plug I really love—BetaBugs MonstaChorus. The VST works fine in jBridgeM, but the AU bridged in 32 Lives will produce a "stuck CD" sound if you stop playback in DP while the plug is passing audio.
- waterstrum
Hey James, did you ever try Bidule?James Steele wrote: Oh and I still have an issue with a old plug I really love—BetaBugs MonstaChorus. The VST works fine in jBridgeM, but the AU bridged in 32 Lives will produce a "stuck CD" sound if you stop playback in DP while the plug is passing audio.
Seems to be a pretty good solution.
I wonder if it could fix your MonstaChorus.
All is well
No... haven't tried it. I've been resisting it. I guess I tried it once years ago and I found it a bit confusing. Also I hear you need to use ReWire? I'm hoping eventually I'll only have a few plugs at most that need bridging and then either 32 Lives or jBridgeM will be a more convenient and robust solution by then. Besides, I've already spent money on both of them at this point, so I'm going to let it play out a bit longer.waterstrum wrote:Hey James, did you ever try Bidule?James Steele wrote: Oh and I still have an issue with a old plug I really love—BetaBugs MonstaChorus. The VST works fine in jBridgeM, but the AU bridged in 32 Lives will produce a "stuck CD" sound if you stop playback in DP while the plug is passing audio.
