I just updated from DP 8.0.4. to 8.0.5.
Previously I had the Audio Performance window separated from the Consolidated Window.
Now it seems like it can ONLY be part of the Consolidated Window.
I go to Preferences -> Display -> Consolidated Window and I deselect Audio Performance from the list under "Open in Consolidated Window", but it makes no difference. The "Processing and Playback" meters remain in the upper right corner of the Consolidated Window.
If I go under the Studio menu and try to select Audio Performance it is grayed out.
Is anyone else getting this?
Is this a bug?
Did something change in 8.0.5?
How do I get the Audio Performance meter out of the Consolidated Window?
Best,
Babz
Can't get Audio Performance Meter out of Consolidated Window
Re: Can't get Audio Performance Meter out of Consolidated Wi
In Preferences --> Control Panel, deselect the Audio Performance option. That will remove it from the control panel in the consolidated window, then you can place it in a sidebar or pop it out.
DP8.06 PT11.2.0 VEP 5.3.x
Thank you, thank you, thank you, NazRat!!!!
I was looking at the wrong Preference setting.
RESOLVED.
Babz
RESOLVED.
Babz
