universal Audio Apollo 16 latency HELP!
I am trying to run a recording session with zero latency monitoring from universal apollo 16 but get the flamming double monitoring effect. Motu's "direct hardware monitor" is greyed out and unavailable using apollo. So while I can track with no latency through apollo console and turning the outputs off in DP, when you want to overdub, you need to turn on the outputs in dp for musicians to hear what they did, that is when you run into the catch 22 of the flamming or double monitoring. Is there a work around? Its very frustrating, and I need to run fairly large sessions and want to use the 16 outs of the apollo to send to a headphone mixer. PLEASE HELP! Turning down buffer size is NOT a solution, it will crash my system as I run large mixes and scores. Thanks
- Dan Worley
Re: universal Audio Apollo 16 latency HELP!
thanks Dan I will try that!
