1) Slate FG-X indeed runs fine but it's still a big hit on the CPU. And for some reason jBridge has that "Performance Mode" option that reduces FG-X's processor hit. 32 Lives can't do this.
2) BetaBugs MonstaChorus (which I love) exhibits an issue. If you stop playback in DP while that plug is passing audio, you will get a stuttering "stuck CD" effect while DP is in stop. Resuming playback will make it stop and playback will continue as it should. MonstaChorus is listed as compatible on the developer's site.
3) Although Altiverb 6 is also shown as compatible, every attempt I made to instantiate it in a project I'm working on now crashes 32 Lives. I'm using Altiverb 6.3.7 which was the last version of Altiverb 6. The Plug In Manager in 32 Lives reports it as version 7.3.7 instead of 6.3.7 for some odd reason. Granted, I could throw $200 at the problem to upgrade to Altiverb 7.... but ouch...
I've reported the issues to the developer.
EDIT: I should add by way of comparison, with jBridgeM Slate FG-X also works fine and you can reduce the CPU hit. MonstaChorus works and does not have the stuttering issue, and Altiverb 6 also works no problem. Although it's not as "slick"... jBridgeM (for now) works better for these particular plugs. It will be interesting to see if the 32 Lives developer can fix these issues. I'm about to try Philharmonik CE in 32 Lives. Just did... it works fine!
