Using Apogee's Maestro software w DP??
mjkeys1
Post by mjkeys1 »
I was hoping someone could pass along some steps in setting up a zero latency mix using DP and Maestro? I've read through a number of older posts, but none really explain how to do this? Currently, I'm hearing latency when trying to monitor using Maestro..which means I'm doing something wrong.
-btw..I can't lower my buffer. I'm currently at 256
Any specifics would be helpful.
Mac Pro 2 * 2.4Ghz Quad-Core, 10.8, 32 gigs of RAM, Digital Performer 8,Vienna Ensemble Pro, bunch of samples...
4stripes
Re: Using Apogee's Maestro software w DP??
Post by 4stripes »
Maestro is completely independent of DP. It is just a digital mixer inside the Apogee, it's Apogee's version of MOTU CueMix. The only way you'll have 0 latency is if you build a mix of inputs bused directly to outputs within Maestro. See your Maestro manual, I'm sure it would discuss this.
You can't have 0 latency when you go through a native DAW like DP. That's why Maestro and CueMix exist to give you a workaround. Native is always getting better, but only a proprietary hardware system can do 0 latency through the software, like Pro Tools HDX. It'll probably be another 5 or more years before native can compete with proprietary on latency. You can see their latency figures here.
mjkeys1
Post by mjkeys1 »
Thanks for your info...
I actually figured out how to route everything this morning. Only weird thing is my mic input. When Maestro is open, I need to crank my avalon M5 mic pre pretty high to get a decent level in DP. If I quit out of Maestro and talk into my mic...it's red-lining. Super hot. Something within maestro must be lowering the level somehow? In Maestro, my LINE 1 INPUT analog level is set to +4 dBU...which is what they said my setting should be if I'm using a pro mic pre. If I switch that to -10 dBU, the level is better, but Apogee said I should be using +4?
Any ideas?
4stripes
Post by 4stripes »
If I quit out of Maestro and talk into my mic... it's red-lining.
Redlining what? The Avalon, Apogee, DP? Quitting Maestro shouldn't alter levels. The Avalon max out is going to be >+24 dBu so +4 is the correct level setting on Maestro.
I would reset all Maestro levels. Sounds like you're attenuating somewhere in there.
plurye
Post by plurye »
I use Maestro's low-latency mixer with DP all the time and don't have this problem. Can you describe exactly how you're routing everything, both externally and within Maestro?
Peter
Todzilla
Post by Todzilla »
I do this a lot and I support the OP's position that it's confusing. I guess I was spoiled by CueMix, which is understandably nicely integrated w DP.
I find the Maestro software very confusing and prone to secretly muting certain outputs. I solved much of this headache by saving a Maestro configuration file which I load first thing.
-Todzilla
Huge sound generation & capture facilities
On the banks of the River Eno
__________________________________________________
DP 8!!!, OSX 10.7.3, 15" MacBook Pro w 16G RAM 256G SSD & 630GHD, MOTU 896HD, MX4, Komplete 8, Apogee Symphony I/O, Neumann U-89, pair of Peluso P12s, Seventh Circle & Demeter preamps, Lava lamp, stuffed frog playing bongos
mjkeys1
Post by mjkeys1 »
I ran some tests and I seem to have gotten it working. I need to get used to it as the software still seems a bit uncomfortable for me....
Thanks for your response. I have a big vocal session tomorrow, we'll see how it goes...
