DP 8.05
Re: DP 8.05
Working beautifully on Intel 2 Duo Core 6 gig RAM.
Less CPU hit, and the new MachFive 3.2 is just as smooth running too.
Way to go MOTU! New life for my old machine!
DP 11, OS Ventura
http://www.cammillarmusic.com
Re: DP 8.05
Uh, welp, I installed 8.05 and proceeded to have a terrible and crashy day, although things seemed to draw faster on the screen. Now, how do I go back to 8.04?
Performer user since--HOLY CR*P--1986? YIKES!
Re: DP 8.05
We might have some comments if you had included your setup in your sig.
Re: DP 8.05
If you want to try and see if we can help, post details of what was happening and your setup.wheever wrote:Uh, welp, I installed 8.05 and proceeded to have a terrible and crashy day, although things seemed to draw faster on the screen. Now, how do I go back to 8.04?
Re: DP 8.05
Easily - but it helps know your setup to point you in the right direction. Knowing what "broke" also helps.Now, how do I go back to 8.04?
You can restore a single application via Time Machine. It will ask if you want to replace the new version with the old or keep both. It is a little known but very cool feature. Tech Support at MicroMat taught me that trick when a new version of TechTool Pro didn't work properly on my iMac and the old version could not be downloaded.
Re: DP 8.05
When I first got 8.05, I had several problems. A re-install cleared everything up. I'm not saying you have a bad install, but I did. Reinstalling might be worth a try.
- Steve Steele
Re: DP 8.05
Before I update to a new version I rename the old version DP 8.04. I've got all of the 8x releases just in case.
Re: DP 8.05
I just use Time Machine.
Re: DP 8.05
Thanks guys, but I really wasn't looking for help as much as just venting. 8.04 didn't crash at all on the same sequences. Nothing else in my config changed between the two versions.
However, just for the sake of explanation, the two crashes I kept getting most consistently yesterday were when I would try and change the buffer size, and when I would try and drag an effect insert. (Usually MW EQ.) The error for the effect insert was something about "bad alloc" but would disappear too quickly for me to see it. Crash logs were unhelpful for anything else. I don't really have time at the moment to dig around and see if I can figure it out, and really the easiest thing would just to back out to 8.04. Usually I keep renamed versions, but for whatever reason this time I didn't.
Sigh.
Re: DP 8.05
I hope when it crashed you got the dialog that asks if you want to send a report to MOTU and went ahead and sent the report. MOTU now has a crash reporter that sends the info to them and that may help them solve it. It's no consolation I know, but I'm not seeing that here.
Just wondering but have you tested RAM with something like Rember? Not likely it's your issue, but I've had RAM go bad and one of the symptoms in general flakiness and instability.
Re: DP 8.05
Repaired permissions? Reset PRAM?
Both can possibly fix this.
Re: DP 8.05
As I mentioned, Time Machine can restore 8.04 - either replace 8.05 or have both up, your choice. 8.04 is still available for download, too.
But we still don't know your setup so if there's anything specific that we can point to and say, that's probably it, you might try..., we won't know it.
This is why we have our setup as part of our signatures; not because we are bragging. It really does help.
Re: DP 8.05
Oh yeah. I'm bragging about a 5 year old machine... actually, it's a very sweet machine.
- mhschmieder
Re: DP 8.05
Is that Food Art or Play-Dough?
- toodamnhip
Re: DP 8.05
DP 8.05 seems to be hanging on shut down for me WAAAAY more than 8.04 did.
I am using it in conjunction with Ve Pro too so I am not sure if that’s an issue?.
The start of Crash report below after force quit:
Date/Time: 2013-10-28 04:13:09 -0700
OS Version: 10.6.8 (Build 10K549)
Architecture: x86_64
Report Version: 7
Command: Digital Performer
Path: /Applications/AUDIO APPS/MOTU APPS/DP 8.05/Digital Performer.app/Contents/MacOS/Digital Performer
Version: 8.05 (8.05)
Parent: launchd [158]
PID: 245
Event: hang
Duration: 5.02s (sampling started after 2 seconds)
Steps: 10 (100ms sampling interval)
Pageins: 19
Pageouts: 0
Process: Digital Performer [245]
UID: 501
Thread d7c DispatchQueue 1
User stack:
10 std::__1::deque<short, std::__1::allocator<short> >::__add_back_capacity(unsigned long) + 2281 (in Digital Performer) [0x100a5dd79]
10 std::__1::deque<short, std::__1::allocator<short> >::__add_back_capacity(unsigned long) + 2506 (in Digital Performer) [0x100a5de5a]
10 _ZNSt3__16vectorINS_4pairIP7glogReciEENS_9allocatorIS4_EEE6insertENS_11__wrap_iterIPKS4_EEOS4_ + 42977 (in Digital Performer) [0x100878371]
10 RunApplicationWithDelegate(int, char**, std::__1::auto_ptr<MOTUApplicationDelegate>&) + 274 (in OSFoundation.dylib) [0x101dd5102]
10 NSApplicationMain + 364 (in AppKit) [0x7fff812223b0]
10 -[NSApplication run] + 474 (in AppKit) [0x7fff812296de]
10 RunApplicationWithDelegate(int, char**, std::__1::auto_ptr<MOTUApplicationDelegate>&) + 2846 (in OSFoundation.dylib) [0x101dd5b0e]
10 -[NSApplication sendEvent:] + 3630 (in AppKit) [0x7fff812926b9]
10 -[NSApplication _handleKeyEquivalent:] + 559 (in AppKit) [0x7fff813c1bed]
10 AdjustLightness(HSLAColor const&, double, double) + 1175 (in OSFoundation.dylib) [0x101e11b27]
10 -[NSMenu performKeyEquivalent:] + 272 (in AppKit) [0x7fff813c2e45]
10 -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 121 (in AppKit) [0x7fff813dd1d4]
10 -[NSMenuItem _corePerformAction] + 365 (in AppKit) [0x7fff813dd46a]
10 -[NSApplication sendAction:to:from:] + 95 (in AppKit) [0x7fff813b8eda]
10 -[NSApplication terminate:] + 325 (in AppKit) [0x7fff8148c542]
10 -[NSApplication _shouldTerminate] + 351 (in AppKit) [0x7fff8148c91d]
10 -[NSDocumentController(NSInternal) _shouldTerminateWithDelegate:shouldTerminateSelector:] + 1207 (in AppKit) [0x7fff8148cf50]
10 -[NSDocumentController(NSInternal) _continueTerminationHavingClosedAllDocuments:context:] + 184 (in AppKit) [0x7fff8148d145]
10 -[NSApplication _docController:shouldTerminate:] + 83 (in AppKit) [0x7fff8148d5c8]
10 RunApplicationWithDelegate(int, char**, std::__1::auto_ptr<MOTUApplicationDelegate>&) + 6422 (in OSFoundation.dylib) [0x101dd6906]
10 OS::EventImpl::DispatchToApplication(UIEvent, boost::optional<MotuOSWindow::OSWindow&>) + 272 (in OSFoundation.dylib) [0x101e23dc0]
10 AppEventFilter::HandleUIEvent(UIEvent&) + 161 (in PerfFoundation.dylib) [0x1028e47f1]
10 IdleOnExit::~IdleOnExit() + 21 (in OSFoundation.dylib) [0x101db2d25]
10 CIdleChore::IdleAndReturnNextIdleTime() + 1321 (in libMotuCoreLibs.dylib) [0x10140bb09]
10 std::__1::vector<ChainOfCommand::HandleBeforeCommands*, std::__1::allocator<ChainOfCommand::HandleBeforeCommands*> >::vector(std::__1::vector<ChainOfCommand::HandleBeforeCommands*, std::__1::allocator<ChainOfCommand::HandleBeforeCommands*> > const&) + 390 (in DPBasicUI.dylib) [0x101772076]
10 ChainOfCommand::Chore::Run() + 173 (in DPBasicUI.dylib) [0x101771a9d]
10 RequestHandler::HandleCommand(RequestHandler*, CommandSpecifier const&, CommandActivator const*) + 94 (in DPBasicUI.dylib) [0x101765dfe]
10 NonSeqDocModelessGlog::HandleCommand(CommandSpecifier const&, CommandActivator const*) + 60 (in DPBasicUI.dylib) [0x1017826ac]
10 Application::HandleCommand(CommandSpecifier const&, CommandActivator const*) + 18 (in DPBasicUI.dylib) [0x101787a62]
10 _ZNSt3__16vectorINS_4pairIP7glogReciEENS_9allocatorIS4_EEE6insertENS_11__wrap_iterIPKS4_EEOS4_ + 18937 (in Digital Performer) [0x100872589]
10 _ZNSt3__16vectorINS_4pairIP7glogReciEENS_9allocatorIS4_EEE6insertENS_11__wrap_iterIPKS4_EEOS4_ + 21291 (in Digital Performer) [0x100872ebb]
10 std::__1::vector<unsigned int, std::__1::allocator<unsigned int> >::__append(unsigned long) + 8198 (in Digital Performer) [0x1002212c6]
10 SCSX_ControlSurface::Finalize() + 13 (in EuCon) [0x13e513967]
10 (anonymous namespace)::Terminate() + 25 (in EuCon) [0x13e51470d]
10 EuphonixSurface::Destroy() + 30 (in EuCon) [0x13e51db7c]
10 EuphonixSurface::ShutdownConsumer() + 33 (in EuCon) [0x13e51da2b]
10 boost::thread::join() + 91 (in EuCon) [0x13e5d5f0b]
10 __semwait_signal + 10 (in libSystem.B.dylib) [0x7fff8431ba6a]
Kernel stack:
10 semaphore_wait_continue + 0 [0xffffff80002815d9]
Thread d90 DispatchQueue 2
User stack:
10 start_wqthread + 13 (in libSystem.B.dylib) [0x7fff842faaa5]
10 _pthread_wqthread + 353 (in libSystem.B.dylib) [0x7fff842fac08]
10 _dispatch_worker_thread2 + 252 (in libSystem.B.dylib) [0x7fff842fb2de]
10 _dispatch_queue_invoke + 185 (in libSystem.B.dylib) [0x7fff842fb7b4]
10 kevent + 10 (in libSystem.B.dylib) [0x7fff842f9c0a]
Kernel stack:
10 kevent + 62 [0xffffff80004786e4]
Thread d8f
User stack:
10 thread_start + 13 (in libSystem.B.dylib) [0x7fff84319e89]
10 _pthread_start + 331 (in libSystem.B.dylib) [0x7fff84319fd6]
10 CanAccessPrecedingBytes(void*, unsigned long) + 698 (in libMotuCoreLibs.dylib) [0x1013f8fba]
10 AllocationUnitTest() + 2122 (in libMotuCoreLibs.dylib) [0x1013f8a7a]
10 usleep + 57 (in libSystem.B.dylib) [0x7fff8431b863]
Kernel stack:
9 semaphore_wait_continue + 0 [0xffffff80002815d9]
1 hndl_unix_scall64 + 20 [0xffffff80002e4874]
1 unix_syscall64 + 544 [0xffffff80004e8168]
1 __semwait_signal_nocancel + 179 [0xffffff8000487442]
1 semaphore_timedwait_trap_internal + 138 [0xffffff8000281c9e]
1 semaphore_destroy + 799 [0xffffff8000281995]
1 thread_block_reason + 264 [0xffffff8000209ab2]
1 thread_go + 2145 [0xffffff8000208fec]
1 thread_setrun + 1344 [0xffffff80002083a4]
1 machine_idle + 210 [0xffffff800022e461]
Report Version: 7
PID: 245
Event: hang
Pageins: 19
Pageouts: 0
UID: 501
User stack:
Kernel stack:
User stack:
Kernel stack:
Thread d8f
User stack:
Kernel stack:
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
