MAVERICKS (10.9) ISSUES & COMPATIBLITY
Re: MAVERICKS (10.9) ISSUES & COMPATIBLITY
Wow, and right on the heels of DP 8.05. Things should get interesting around here.
Oooo ahhhh.... games to play this week! Thanks for the info. Also on the heels, literally, of MachFive 3.2 today.
http://www.motunation.com/forum/viewtop ... =5&t=55881
This just about covers it all:
http://arstechnica.com/apple/2013/10/os-x-10-9/
- adriano
Hello forum,
OK, in my sig you can see the Mac I'm using. This is my test machine and if it performs well on the iMac, it'll be even better on the MacPro.
Installed OS X 10.9 and below are the apps I'm using on this iMac:
DP 8.05 = Checks
QuickTime Pro 7.6.6 = Checks
DSP-Quattro 4.2.2 = Checks
Bidule 0.9733 = Checks
SampleTank = Checks
Miroslav Philharmonik = Checks
SampleTron = Checks
SonikSynth = Checks The VIs in blue, are loaded into Bidule
Independece Pro = Checks
GPO, GIO and all other Garritan libs = Checks
For system maintenance:
iDefrag 2.4.4 = Checks
TinkerTool System 3.2 = NO... I guess I can use OnyX
Adriano
EDIT:
TinkerTool System has been updated to 3.3. So, this checks also.
RE-EDIT:
Microsoft Office 2008 is also still working
DP 8.05 = Checks
SampleTank = Checks
SampleTron = Checks
Adriano
EDIT:
RE-EDIT:
iMac9,1, 3.06GHz Intel Core 2 Duo, 8GB-RAM, 10.9.5
DP 8.07, 828MKIII, Keys-Fantom X8, XV-88. Key
SampleTank v2.5.4, Miroslav Philharmonik v1.1.2, SampleMoog v1.02, SampleTron v1.02, Sonik Synth 2 v2.1.1, Independence Pro v3.2.0126, EZDrummer 1.4, MDrummer Large 5.02, Komplete U9, Orchestral Essential 1, Orchestral Essential 2, Complete Orchestral Collection
Music is the wine that fills the cup of silence.
Thanks for that. Still 20 min. To finish the install.
- adriano
You are quite welcome.MIDI Life Crisis wrote:Thanks for that. Still 20 min. To finish the install.
10.9 seems a bit faster also compared to 10.8.5. As I said, the iMac is 4 years old and only 8 GIGS of ram, but for testing purpose, it's ok.
BTW:
Welcome back, MIDI lIfe Crisis.
Adriano
Installed 10.9 last night. Using MOTU Traveller (mk I) with various DAWs. No issues detected so far.
Mainstage 2 32 bit bridge broken. Similar Logic results?
Logic Pro 9.1.8 works in both 32bit and 64bit. In 32bit, Logic runs some plugs that DP 7.24 will not run such as Ozone 5.04 and Alloy 2.02 (see Izotope's tech notes on this).cuttime wrote:Mainstage 2 32 bit bridge broken. Similar Logic results?
http://www.izotope.com/support/portal/i ... ugin_hosts
So far for me, 10.9 has broken Audio Ease Snapper(v.2), and Standalone Versions of EWQL Symphonic Orch(ver.4.0.23) & BFD3. Both EWQL & BFD3 work fine when loaded as VIs inside DP8.
rich
rich
2013 Mac Pro 2.7 Ghz 12 Core Intel Xeon_128G Ram_OSX 12.7.6_DP 11.32
Snapper is broken and has an update but you can't update from 10.9. I'll try from 10.8 and see if that works in 10.9.
No dice. Snappier is not only not Snappier in 10.9 but broken. Kaput.MIDI Life Crisis wrote:Snapper is broken and has an update but you can't update from 10.9. I'll try from 10.8 and see if that works in 10.9.
I have a similar experience with EWQL Symphonic orchestra. Works inside DP8.05 or Bidule and does not as standalone.
Can anyone test in 10.9:
*** Wallander wind/brass AU inside DP 8.05
*** NI Kontakt 5.3.0 Standalone and AU inside DP 8.05
Some users report Kontakt crashing in Mavericks but they do not specify if it is a fresh version 5.3.0 and if it concerns standalone, AU or both. So far no news about Wallander...
+372 56222285
