Need help Seting up Audio Playback
So I have a Yamaha Audiogram 3 USB audio interface. I have the Audiogram as the input for the track and i have my headphone jack on my laptop as the output. I can hear the instruments i have connected to the Audiogram and i can even record the tracks and i can see the wave form of the audi track....but when i press play, i hear nothing. Im new at this and dont entirely know what im doing. I just want to be able to record some audio and play it back
pleas help!
Asus G73SW
Intel i7 2630QM Quad Core
8gb DDR3
x2 1TB HDD
FantomX8 Workstation
8gb DDR3
x2 1TB HDD
Re: Need help Seting up Audio Playback
Do you have the Audiogram selected as an ASIO audio device in DP 'Configure Hardware Setup'? If so, have you tried connecting the phones to the phones output on the Audiogram? You appear to be trying to use two audio devices - one for input (Audiogram) and one for output (PC phones). If your Sound Control Panel is configured this way, you can also try selecting Windows Audio in the configure hardware dialog rather than an ASIO device.
DP8.06 PT11.2.0 VEP 5.3.x
So i do have the Audiogram selected in the ASIO settings. I cant get DP8 to recive audio trough the Audiogram, and DP8 does output the sound to the headphone jack in real time....the problem is playback. When i play recorded audio back, i get no sound....NazRat wrote:Do you have the Audiogram selected as an ASIO audio device in DP 'Configure Hardware Setup'? If so, have you tried connecting the phones to the phones output on the Audiogram? You appear to be trying to use two audio devices - one for input (Audiogram) and one for output (PC phones). If your Sound Control Panel is configured this way, you can also try selecting Windows Audio in the configure hardware dialog rather than an ASIO device.
OH im silly, i figured it out. All i needed to do is un-check Input Monitor....ok its all good. Im learning how to use this program in my audio tech class but we havnt gone into recording audio yet :S
Thanks for the response!
Asus G73SW
8gb DDR3
x2 1TB HDD
8gb DDR3
x2 1TB HDD
