HI All, anyone happen to have a MIDNAM file for a Kurzweil PC3X they would be willing to share. I recently upgraded to DP8 from 7.24 and lost the one I had created in CherryPicker.. yup cherrypicker does not run in Mountain Lion and I had no backup..DUH.
Also if anyone has a suggestion as to what to use to create a Midnam file for DP8 please let me Know. Thanks for your consideration in advance.
Mike
Kurzweil PC3X Midnam File in DP8
Re: Kurzweil PC3X Midnam File in DP8
.midnam files use text-based XML markup language. Most any text editor that does not change the format should work, Text Wrangler gets lots of use over here.
I have a PC3LE6 .midnam you are welcome to - don't know if it would be close enough to your model to make it worthwile as a starting point.
MacBook Pro 9,1 15" 16gb | 10.12.4 | DP 9.13 | xAir | NI | WIVI | Garritan | Izotope | Bidule
Thank you so much for the info and being willing to share.. If you could email to me, I will use that as a basis to adjust to fit my PC3X setup..
Please send at your convenience..
Mikesr@plushnyc.com
Best Regards and thank you so much
Mike Levesque
Sound Design/Partner
PLUSHnyc
www.PLUSHnyc.com
Mikesr@plushnyc.com
Mike Levesque
PLUSHnyc
www.PLUSHnyc.com
sent.
