DP8.0.4 in 64bit mode not seeing 64bit plugs
stevelees
Post by stevelees »
I am having problems with DP8.0.4 in 64bit mode not seeing 64bit plugins, today it is Drumagog that it will not see at all. Other applications such as DSP-Quattro has not problem, but DP8 simply does not see it. Any ideas welcomed....
Cheers, Steve...
NazRat
Re: DP8.0.4 in 64bit mode not seeing 64bit plugs
Post by NazRat »
Not sure about Drumagog, but I believe DSP Quattro is still 32 bit and would only see 32 bit plugs.
DP8.06 PT11.2.0 VEP 5.3.x
David Polich
Post by David Polich »
Do you have the latest version of Drumagog, which is 64-bit? It's available
from the Drumagog website.
http://www.davepolich.com
