Why my keyborard starts and stops the sequence?
dimira
Post by dimira »
Hi everybody,
I usually use to connect my keyboard (M-Audio keystation 49)
to a Motu Ultralite connected with a MacBook Pro and Digital Performer 6.03
to play virtual synths.
Two days ago i switched on all this stuff and magically
i realized that the keyboard didn't sound any notes between the first and the second octave
but it starts and stops the sequence.
Any suggest?
Did i unconsciously switched on something?
Please let me know,
Thanxs
Phil O
Re: Why my keyborard starts and stops the sequence?
Post by Phil O »
Read the section on MIDI Masters in the DP manual. (p. 148 in DP7 manual). You can start by simply un-checking the Master Master in the Commands window under MIDI Masters and see if this fixes the problem. If that works, you can delve into these settings to suit your needs.
dimira
Post by dimira »
Thank you Phil, seem it works.
I don't know hoe i activated it but, i will remember for the next time.
...such a stupid thing.
take care,
L
daniel.sneed
Post by daniel.sneed »
DP Command window is a very deep and powerful tool.
So deep, from time to time it brings tricks.
BTW, view filter is known to do that, too...
Phil O
Post by Phil O »
Glad I could help. 8)
