usbovine wrote:Yes, this is incredibly annoying!
Not in my DP; only Select All works. Deselect All brings up the last selected track. Am I overlooking a setting?Dan Worley wrote:make sure you hit Command D (Deselect All) before switching to it.
usbovine wrote:Not in my DP; only Select All works. Deselect All brings up the last selected track. Am I overlooking a setting?Dan Worley wrote:make sure you hit Command D (Deselect All) before switching to it.
"Show All Tracks" should at the very least be available as a key binding.
Just noting that you can also take the TO out of the CW, or keep both open in the CW; more or less anything that keeps both open at the same time.Dan Worley wrote:The only thing you can do now is take the mixer out of consolidated windows and leave it open all the time, or make sure you hit Command D (Deselect All) before switching to it.
It's the only way that I can work.The only thing you can do now is take the mixer out of consolidated windows and leave it open all the time,
Can you put the CW in one monitor in full screen mode and keep the mixer in the other monitor?mikehalloran wrote:With decent (OK, not great but decent) 23" monitors available in the $125-$150 range, having a second one just for my plug windows and mixer makes my work flow much better.
Yes. I never tried it before now but that works quite well. The mixer board and other floating DP windows on the 2nd monitor stay in place and do not change while the CW goes full screen on your main monitor. Pretty cool, actually.Can you put the CW in one monitor in full screen mode and keep the mixer in the other monitor?
