Yes, I have a VTVM, no scope but i have just never seen a published spec on MOTU IO's.magicd wrote:Admit what? That's the spec of the unit (actually, to be precise, 18dbv is not the clip point. 18dbv is the ceiling. Anything above 18dbv will clip the input). It's also the same spec for the Traveler, 828mkII, 2408mk3, 24i/o and HD192 interfaces. It's very easy to check on input and output. All you need is a test tone generator and an accurate analog VU meter.Timeline wrote:
Has someone finally admitted here that +18 db is the clip point in MOTU IO's
Dave
Also, when bridging, OP level seem adequate but looking into into lower impedance loads, levels are pressed. My API 8200's load HD192's easily. A UA 2192 can perform with much better headroom and output by comparison.
I wonder why more expensive IO's have more headroom?
