networked ports MTPAV-MTPII (9-16) don't appear in Win XP
doublecero
Post by doublecero »
I have set a network system with a MTP AV and a MTP II. I am working with an Athlon 1500+ PC running Windows XP Professional SP2, and have installed the latest XP driver from the MOTU website (SETUPMIDI_2.51.zip).
The interfaces work in standalone with each other without any problem. Even on the Clockworks console I am able to see all the 16 ports at once, but each time I run my sequencer (Cubase SX 3), I can only route the first 8 MIDI ports, the networked ports (9-16) aren't present there. When I look at the Device Manager I see only the first 8 ports.
Thank you in advance for your help
greggybud
Post by greggybud »
I too am expierencing the very same problem with two identical MIDI Timepieces AV serial port.
Clockworks recognizes 16 in and out ports, but Cubase only recognizes 8 ports.
Help!
greggybud
Post by greggybud »
Doublecero:
I have sent you another PM.
MOTU tech support..... finally after 6 calls in 3 days decided to set up 2 networked MIDI timepieces parallel ports to Windows XP and they too cant get ports 9-16 to work. It shows up in Clockworks but when you open Cubase, or any other sequencer it will only show ports 1-8.
Frustrating I had to go through so many tech support guys before I could convince one of them to actually try this out.
Im surpprised no one else has encountered this problem even realizing parallel ports have been replaced by USB.
DJLucifer
Post by DJLucifer »
Hello,
I have the same problem !!!
But i must after the Windows start to klick LPT-Refresh, and then shows all Port !
Give as a another Solution ??
gillesalphonse
Re: networked ports MTPAV-MTPII (9-16) don't appear in Win XP
Post by gillesalphonse »
Well I encounter the same problem : 2 MTP AV (parallel, the old goodies ... ) networked , Clockworks detects the 16 ports , but neither Win XP SP2 , nor MIDI OX , nor SONAR detect the 16 ports , they stay with the original set up , i.e. 8 ports
I guess this topic is well known , so the question is simple : is it possible to have the 16 ports ( parallel ) detected by Windows ? Is it a driver issue ?
Does MAC OS does the trick ? which OS ?
